Please Support ExtremePSI
Please Support STM Tuned
ECMlink dip in idle. want you to check it out
bowens1414
123
Oct 30, 2012
Bradenton, Florida
finally got my cable to look things over and help get the idle dialed in and caught a few dips once she warmed up. i just want you guys to check it out as i think it is in the tune. first dip happens at 84 seconds. sorry for the long log. thought i was just live streaming it!
  • log.2019.11.19-01.elg
You need to be logging a ton of other stuff. iscposition, map sensor and wideband to name a few. Go under "ecu inputs" tab and change your pin assignments for rear o2 and mdp to wideband and map sensor respectively. Save the pin assignments. Take another log with all these values captured.
I can't find that under that tab I may have to upgrade firmware. But I made it a little better. I entered the SD temp weighting numbers and bumped the fiav no a/c numbers at 190 and 160. Doesn't die or fumble but has a quick dip to 750 up to 950 and settles in at 900. And it only does it the one time. I'll throw up another log tomorrow once I play more and set the biss and iacv manually
