nek
- 832
- 9
- Apr 17, 2009
Pittsburgh,
Pennsylvania
Hey guys,
My car is acting up again as usual and now its keeping me from work. Initially when it warmed up to a certain temperature, it would start jerking (fluctuating between accel and decel) when I was cruising at ~2200 rpm constant throttle.
Now it seems like when I start it up, it just starts doing it right away.
Under constant throttle,
afr goes lean,
rpm jerk around
and for some reason my coolant gauge will show overheating under throttle then jump back down right when I lift off even though my ecm link is showing normal temperatures. Its hard for me to finger point this so i am just trying to throw things out there to see it rings a bell. (no its not fuel cut)
Also, It started today about 15 miles from home, while I was on the highway at 60 mph low rpms, the throttle just cut out completely, I couldnt accelerate I could only coast..... turned it off and turned it back on, now I could accelerate again
Anyways here is a video,
Dsm cruise issue - YouTube
And some logs below, first (short one) is idle second is starting up and cruising around trying to catch the problem. Notice at the end, in park at constant throttle how the afr is just jumping around and going lean.
On a side note, when your car is powered on without the engine running, does the brake / at temp/ and battery light come on? I know if they come on while running it means you could have a bad alt but what if the engine is off?
afr goes lean,
rpm jerk around
