dead cooling fan?
jagrjones
47
Aug 23, 2002
Fallbrook, California
My cooling fan has not been coming on (overheating at idle) and I was just wondering if when I turn the AC on, are both fans supposed to come on? I think my cooling fan is dead.
Both fans should come on when you turn on the A/C. at least on my car they do. If they do, then your fan switch is bad. Located on the bottom of the radiator net to the lower hose. Unplug the wiring connector from the switch, jump it out witha paper clip, if the fan works, then the switch is bad. If the fan doesnt work, then it's probably the fan.
  • For sale 1g Oil return mhi
    1g oil returns
    • 92AWDHX40
  • For sale 2g awd rear hubs
    2g awd rear hubs with arp extended studs.
    • jweber
  • For sale 2ga Auto vss NOS
    2ga auto vss sensor and and driven gear. New old stock
    • jweber
  • For sale 4G63 Dynatek Arc-2 brackets
    Dynatek Arc-2 brackets. Were originally for mounting the box on an Evo. Stainless. One has...
  • For sale Evo3 16G
    Bought this from a member here. Used it for about 150 miles then swapped it out for a more...
    • silentsnow31802
