kingearl
- 209
- 0
- Jun 6, 2002
Edmonton,
Ok, I will set these up in point form. question me on whatever is needed to make things right. My boost is set to 9psi do to my resent engine rebuild. Mods are on my list. Thanks for any advise you may be able to give.
1. My throttle percentage at idle is 0% on the AFC but 10% on the datalogger. Wut up wit dat?
2. My injector pulse width shows that the duty cycle is 10-40% MAX at WOT. This is on my stock injectors. Wut up wit dat?
3. My timing advance shows a base of around 11 and at WOT peaks between 38 and 42! Wut up wit dat?
4. I have logged with settings on the AFC from -1 across board in one run to +20 across the board the next with no real noticable differance in the logs. Wut up wit dat?
With all this going on my knock isn't severe at peaks of 12 but mostly between 1-4.
And just a general question, is fuel trim supposed to be constant all the time or is it supposed to flucuate during runs? Thanks again.
