Brian Phelps
- 0
- Apr 14, 2020
Enfield,
New_Hampshire
So I've done extensive work on my Cylinder head, intake Manifold, exhaust manifold, throttlebody, injectors, turbo, and head internals.
Parts List:
80mm Throttlebody,
Custom Intake manifold (NO MAP Sensor),
2250cc injectors @5bar
Aluminium fuel rail
100lbs Holly Fuel Pressure Regulator
295lbs Valve Springs
Solid Lifters,
86mm cans,
Forged steel valves,
Forged steel spring caps and seats,
Ram horn even flow headers
57/59 T3/T4 Hybrid Ceramic Ball bearing Turbo Charger,
3" down pipe,
Trial Wastegate.
I've deleted the cruise control, egr valve, MAP sensor, IACV, and a bunch of vacuum line stuff, the intake has 3 vacuum line fittings on it and a brake vacuum assist fitting. Could anyone tell me if I need the MAP sensor, or if the 7 wire MAF sensor will be enough. Also I know I need a Vacuum line for the turbo, boost gauge, brake booster, fuel pressure regulator, but is there anything else that needs manifold vacuum pressure to assist the engine in daily operations? Yes I'm planning on driving this on the roads as a road legal car.
Parts List:
80mm Throttlebody,
Aluminium fuel rail
Solid Lifters,
86mm cans,
3" down pipe,
Trial Wastegate.
