Paul@RTM
Supporting Vendor
- 684
- 448
- Oct 24, 2012
Hamilton,
ON_Canada
We're doing some R&D on this brake upgrade and we've encountered a curiosity.
We've got all the relevant parts (2g knuckle, CTS-V caliper, Cobra rotor, wheel spacers) and when we assemble everything (using a 5mm spacer between the hub flange face and the rotor) we find that the rotor does NOT locate to the centerline of the caliper. We find it's off by about 1.4mm (such that a 6.4mm spacer, NOT a 5mm spacer would be required to match the centerline of the rotor to the centerline of the caliper). We tried it with several different combinations of rotor, caliper, knuckle (to ensure there were no oddball parts) and got the same figure each time.
As far as we know, the adapters CTSVBrakeSwap.com sells are 5mm thick. All references from all sources we've found speak of 5mm spacing/removing. Are we missing something?
Anyway, our question to anyone that has done this mod: did a 5mm spacer match up the rotor/caliper centerlines? Or for those who machined material off the caliper mounting ears, did removing 5mm match up the rotor/caliper centerlines?
The reason we're asking is that we're considering offering CTS-V calipers for sale that have had the appropriate amount of material machined off. Of course, we'd like to machine off the correct amount. There is at least one good reason to go this route, rather than spacing the rotor: it places everything (especially the caliper) 5mm? 6.4mm? more inboard and thus gives that amount more clearance for rims.
Thanks in advance.
Thanks in advance.
