Rollinukwn
- 77
- 0
- Nov 4, 2010
St Louis,
Missouri
90 Talon 5-speed -awd ...
Ok soooo now that shes moveing under her own power after the 91 ecu swap every thing is great ....
BUT...... Well when you drive normal its fine but when you try to shift over 4500 rpms its like 2d isint even there no grinding NOTHING like the gear isint even there.
I just bought the car from a trusted friend and its always been like this ... its had maybe 300 miles on it in 4yrs .
Mods ... big16g(ported) mbc, hard pipes,Underdrive crank pulley ,2g man (ported) .
The car pulls nasty on just 12lbs .. way harder then the colt did with the 4g63 swap i just wish i could figure this out without buying a trans ... my luck it is but just maybe its an adjustment ?
What do you guys think...?
Also some times it grinds in reverse even if you put it in 4th then try to go to reverse?
Thanks for you time guys.
Rob.
Rob.
