crowa95
- 0
- Jan 7, 2023
PERU,
Indiana
Hey guys, I was wondering where the crankshaft sensor is located and if it could cause my car not to have spark or fuel?
So I did check for fuel and spark but don't have any the car cranks and ever other feature worksTell us what you've done so far. You have multiple threads all about similar subjects. What have you tested/repaired?
Well you at least need to check and see if fuel pump circuit works. I bet it doesn't given how long car has been sitting. Go through the no start post. Ask questions as necessary. You may have multiple problems. Eliminate them one at a time.I unhooked the fuel line and then turned the key after putting fresh fuel in it after the tank was drained. For spark after I replace the plug cables I took out cylinder ones plug and held it against the block while someone cranked the motor and the plug had no spark.
