vanhagar
- 0
- Jul 18, 2010
westminster,
Maryland
CRANKSHAFT Sensor 95 mitsu eclipse GSX stock
My Daughters balance shaft sprocket belt broken and just about blew out the timing belt as well. During the disassemble process I also seen the crankshaft position sensor was just about destroyed. If you are familiar with the sensor looking at it from the side it is almost shaped like an h with a small magnet inside. On the crank shaft sprocket there is a 2 half moon plates on both sides. I did not take notice when I removed the broken parts how it was positioned. As I said it was just about destroyed. It seemed simple enough.
So what I am asking is when the 2 half moon plates rotate with the crank shaft sprocket do they go thru the sensor. It seems that way to me but when I tried it, the plates damaged the small magnet. So I was thinking when the belt blew out it bent the half moon plates so they contact the sensor. Am I correct with my assumption. I have the Hayes book & searched the net but everything says install the sensor the opposite as removed.
