1. Join the Community!
2G Crankshaft pulley wobble
Posted by MasterMatt209, Jul 23, 2019
Please Support Rix Racing
  1. MasterMatt209
    MasterMatt209 Proven Member
    422
    26
    Joined Jan 17, 2015
    Danville, Indiana
    As I was putting my alternator belt on I started the car to check for squeal before I put the splash guards back on and such, I noticed my crankshaft pulley was not only wobbling but missing a bolt too. What’s the rundown here?
    394  1
    1995 Mitsubishi Eclipse GSX
    awd · automatic · 2G DSM
    516  3
    1995 Eagle Talon TSi AWD
    Street Build 884  0
    1998 Mitsubishi Eclipse GSX
    automatic · 2G DSM
    Loading...
  2. Mello
    Mello Proven Member
    956
    234
    Joined Jul 4, 2003
    Albuquerque, New Mexico
    Most likely the inner & outer are separating from each other & it's time for a new harmonic balancer. The isolating rubber section has deteriorated & is coming a part.
    silvreclips likes this.
  3. MasterMatt209
    422
    26
    Joined Jan 17, 2015
    Danville, Indiana
    How bad is it to replace?
    394  1
    516  3
    Street Build 884  0
    automatic · 2G DSM
    Loading...
  4. Mello
    Mello Proven Member
    956
    234
    Joined Jul 4, 2003
    I think it would be good to replace.
  5. 2gmitsueclipse
    2gmitsueclipse DSM Wiseman
    2,066
    613
    Joined Jul 13, 2005
    Auburn Hills, Michigan
    Well, you already have one bolt out, so three more and pop it off. Obviously, you will need to loosen the accessory belts. If you cannot remove it due to hitting the frame rail, place a jack with some wood on it under the oil pan to support the engine. Just using the jack could damage the oil pan. You can now remove the upper engine mount on the timing side. Use the jack to slowly lower the engine on the timing side to clearance the crank pulley.
    Autocross Build 18K  47
    awd · manual · 2G DSM
    Street Build 2K  0
    1999 Mitsubishi Eclipse GST
    manual · 2G DSM
    Autocross Build 3K  0
    1990 Plymouth Laser RS Turbo
    manual · 1G DSM
    Loading...
    1990TSIAWDTALON likes this.
  6. MasterMatt209
    422
    26
    Joined Jan 17, 2015
    Danville, Indiana
    That doesn’t sound too hard, when researching I thought this part had something to do with timing and I would have to take the timing belt off and stuff
    394  1
    516  3
    Street Build 884  0
    automatic · 2G DSM
    Loading...
  7. MasterMatt209
    422
    26
    Joined Jan 17, 2015
    Danville, Indiana
    I’m sorry what I meant was how bad as in how hard would it be? I’ve done lots of engine work but never this specific task
    394  1
    516  3
    Street Build 884  0
    automatic · 2G DSM
    Loading...
  8. curt-s
    curt-s Proven Member
    762
    215
    Joined Dec 21, 2008
    Winterville, MB, Canada
    Street Build 2K  1
    1991 Eagle Talon TSi
    fwd · manual · 1G DSM
    Loading...
    MasterMatt209 likes this.
  9. motomattx
    motomattx Proven Member
    1,919
    675
    Joined Dec 9, 2010
    wampum, Pennsylvania
    That should come right off without even jacking up the engine, just pull the four bolts and wiggle it right past the body and it should drop down and out.
    Drag Race Build 3K  24
    1995 Mitsubishi Eclipse GST
    fwd · manual · 2G DSM
    Loading...
    ThunderChild likes this.
  10. ThunderChild
    ThunderChild Supporting VIP
    2,540
    714
    Joined Jan 5, 2012
    Rathdrum, Idaho
    Correct. Just take the belts off, undo the bolts and slide it out. For a good replacement, OEM or a fluidamper would be my recommendation :thumb:
    Street Build 251  3
    1990 Plymouth Laser N/T
    356  8
    1987 Toyota Pickup/Hilux
    awd · manual · Misc Vehicles
    Street Build 895  7
    1997 Mitsubishi Eclipse Spyder GST
    Street Build 1K  1
    1992 Eagle Talon TSi AWD
    manual · 1G DSM
    Street Build 2K  10
    awd · manual · 1G DSM
    Loading...
  11. my98gsx
    my98gsx Proven Member
    494
    43
    Joined Aug 14, 2005
    Wappingers, New York
    You need to fix this immediately. Its adding unwanted vibration on your crank. You can get replacement bolts from any hardware store for the crank pulley, they are nothing special. Inspect the pulley and make sure it has not been damaged or separated. If so, do not reinstall. You do not have to remove the center bolt, but sometimes the pulley gets stuck to the timing gear behind it. Some light taps with a rubber mallet usually break it free without issue.
    Street Build 602  11
    1999 Mitsubishi Eclipse GSX
    563 whp · 422 lb/ft · 2G DSM
    711  4
    12.091 @ 114.490 · 2G DSM
    Loading...
  12. tk106
    tk106 Supporting Member
    1,771
    497
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Yes ASAP. Mine just came apart. Now I need a new cover and timing belt along w damper. Looks like you don’t have ac so just loosen the alternator belt.
    BBBD6C73-FED2-4BFF-A486-CDE45E6CCAA7.jpeg D7DE7DCC-F2E8-4101-9C0F-B969ED18DDB0.jpeg 029B46E3-87F1-490F-8897-90FB705D839F.jpeg
    171  3
    2000 Jeep Cherokee Sport - Classic
    awd · automatic · Misc Vehicles
    173  4
    93 Civic 4 Door -sold-
    fwd · manual · Misc Vehicles
    Street Build 2K  6
    12.625 @ 111.42 · 1G DSM
    Loading...
  13. tk106
    1,771
    497
    Joined Sep 11, 2017
    Cincinnati, Ohio
    You might be able to break the bolts loose first and then loosen the alternator belt
    171  3
    173  4
    Street Build 2K  6
    Loading...
  14. Boomdeeze
    Boomdeeze Proven Member
    1,627
    270
    Joined Jul 5, 2009
    Independence, Minnesota
    You do have to lower the engine to get the pulley to clear the frame rail. Like mentioned above, put a floor jack under the pan to support the engine and loosen the driver side motor mount. You won't have to take the mount off just loosen the two nuts on the studs and remove the bolt, the engine will move enough for the pulley to clear.
    Street Build 4K  1
    1997 Mitsubishi Eclipse GSX
    10.793 @ 128.98 · 2G DSM
    Loading...
  15. tk106
    1,771
    497
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Guess it’s different for 1g. 1g has enough clearance.
    171  3
    173  4
    Street Build 2K  6
    Loading...
  16. MasterMatt209
    422
    26
    Joined Jan 17, 2015
    Danville, Indiana
    Thank you for all of the good information I will be ordering an OEM pulley at the end of this week. So floor jack on the oil pan to support engine? Also would this be a good time to swap that engine mount too? Maybe not the mount but the insert at least? If so what’s a good replacement
    394  1
    516  3
    Street Build 884  0
    automatic · 2G DSM
    Loading...
  17. motomattx
    1,919
    675
    Joined Dec 9, 2010
    Try taking it out without lowering the engine, I have never had to touch a motor mount to take one out and I just did one two months ago, I also did my 4g64 Spyder in my driveway after work one night and never touched a motor mount and its all stock, either I'm a magician or just really good.
    Loading...
  18. 2gmitsueclipse
    2,066
    613
    Joined Jul 13, 2005
    Before you purchase an OE, look into spending a little more to opt. a Fluidampr.
    Street Build 2K  0
    manual · 2G DSM
    manual · 1G DSM
    Loading...
  19. MasterMatt209
    422
    26
    Joined Jan 17, 2015
    Danville, Indiana
    I thought about it, it seems that’s for an engine that’s modified a little more than mine. I have an egr delete and a filter for the maf and that’s about it. Do you think the fluidampr would benefit a mostly stock DD?
    394  1
    516  3
    Street Build 884  0
    automatic · 2G DSM
    Loading...
  20. MasterMatt209
    422
    26
    Joined Jan 17, 2015
    Danville, Indiana
    Yeah I’ll try to take it out without jacking the engine first
    394  1
    516  3
    Street Build 884  0
    automatic · 2G DSM
    Loading...
  21. motomattx
    1,919
    675
    Joined Dec 9, 2010
    Its very tight but its do-able.
    Loading...
  22. 2gmitsueclipse
    2,066
    613
    Joined Jul 13, 2005
    It sure will. It won't fail like the OE design.
    Street Build 2K  0
    manual · 2G DSM
    manual · 1G DSM
    Loading...
  23. tk106
    1,771
    497
    Joined Sep 11, 2017
    Cincinnati, Ohio
    If you have to jack the motor, put a piece of 2x4 between the jack and pan so you don’t damage the pan. But from what the 2g guys have posted, seems like you shouldn’t have to touch the mounts like a 1g
    171  3
    173  4
    Street Build 2K  6
    Loading...
  24. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    4,595
    2,023
    Joined Nov 14, 2013
    Independence, Kansas
    Man Tony, that one of yours was SUPER bad. Hope it didn't hurt anything or anyone! WOW!
    Street Build 3K  27
    awd · automatic · 1G DSM
    548  14
    1990 Mitsubishi Eclipse GSX
    451  18
    1967 Chevrolet Camaro RS
    rwd · automatic · Misc Vehicles
    Street Build 655  7
    1998 Eagle Talon TSi
    Street Build 5K  11  25
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 · 1G DSM
    Loading...
  25. tk106
    1,771
    497
    Joined Sep 11, 2017
    Cincinnati, Ohio
    I know. Timing jumped too and I think a piece of the cover caused that and also damaged the tbelt. I reset timing yesterday and it was 120 110 110 110. Motor turned fine but I won't know until I get the belt next week. Fingers crossed :pray:.
    I checked the damper in February when I refreshed the head and the rubber looked fine, no cracks. But I did install the alternator pulley backwards when I ported the OFH a few weeks ago and I think that with the age helped breaking apart the rubber.
    171  3
    173  4
    Street Build 2K  6
    Loading...
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
