1greyawdtsi
- 80
- 10
- Sep 18, 2009
Seattle,
Washington
Hi. My 95 Talon Tsi awd 5 speed had intermittent power loss for a couple days then fortunately at home in my garage it devolved into a no start condition. Like the kids say I reflexively threw my purse at it and I installed a larger fuel pump - to no avail.
So I grabbed an OBD2 reader and it threw 1 code - 0335 Crankshaft Position Sensor A Circuit.
I pulled the accessory belts and timing covers. Note I’ve had a slightly leaky power steering pump for years and it looks like a little oil and dirt over the years gummed up the crankshaft position sensor and trigger plate was also slightly dirty & oily but otherwise fine.
I’ve carefully cleaned the area and the CP sensor and all timing marks are good. I’ve searched but found no threads. So my question is if every thing is safely out of the way is it reasonable to test fire the engine to see if the cleaning the CP sensor & trigger plate may have worked - before I replace it?
I realize the water pump would not be circulating. If it fired it would only be running for a minute or two.
Before I attempt that I’m was curious if I’m missing something or shouldn’t attempt to start or fire the engine with all the accessory belts and all timing covers removed? Any insight is appreciated, thanks!
