1. Join the Community!
2G Crank no start/ what I’m I overlooking
Posted by miliman13, Aug 8, 2019
Please Support RTM Racing
Please Support Southbay Fuel Injectors
  1. miliman13
    miliman13 Proven Member
    1,957
    274
    Joined Jan 1, 2011
    tampa, Florida
    here’s a lill history because I know it will come up
    I’ve built the car over 10yrs now
    2 summers ago she made 530hp blah blah
    I’m obsessive; so I’m very meticulous
    This why I haven’t had to touch her in two years now for anything.
    I have verified the following
    Spark
    Fuel
    Fuel pressure
    Compression
    Mechanical timing
    Ignition timing
    I still changed out plugs / coils/ power transistors/
    Speed density sensor
    And nothing...
    So it’s something else not so common; that’s what I need help investigating
    Thanks all.
    “””Ps she went from perfect, to this over night while parked”””
    3K  0
    1998 Mitsubishi Eclipse GSX
    manual · 2G DSM
    1K  0
    13.066 @ 106.880 · 2G DSM
    Loading...
  2. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    7,094
    3,256
    Joined Nov 14, 2013
    Independence, Kansas
    Check the coolant temperature sensor.
    Street Build 5K  31
    1992 Eagle Talon TSi AWD
    14.74 @ 117.04 · 1G DSM
    2K  15
    1990 Mitsubishi Eclipse GSX
    awd · manual · 1G DSM
    992  18
    1967 Chevrolet Camaro RS
    rwd · automatic · Misc Vehicles
    Street Build 1K  7
    1998 Eagle Talon TSi
    fwd · manual · 2G DSM
    Street Build 7K  16  26
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 · 1G DSM
    Loading...
    arodgst and lglracer like this.
  3. miliman13
    1,957
    274
    Joined Jan 1, 2011
    tampa, Florida
    Please elaborate I’ve stumbled upon this very same
    Exact
    Statement.....
    What and how does this work within my circuit ?
    I was under the impression this is a 1g thing only
    3K  0
    manual · 2G DSM
    1K  0
    Loading...
  4. 1990TSIAWDTALON
    7,094
    3,256
    Joined Nov 14, 2013
    Street Build 5K  31
    2K  15
    992  18
    Street Build 1K  7
    Loading...
    ThunderChild likes this.
  5. greddy_1700
    greddy_1700 Proven Member
    955
    41
    Joined Aug 27, 2006
    Regina, SK, Canada
    Condition of capacitors in ECU? Recently had caps that were just starting to leak produce a no start condition.
  6. miliman13
    1,957
    274
    Joined Jan 1, 2011
    tampa, Florida
    Well mines is working fine from what I can test through link
    85f on a 85f day
    Doesn’t show the -40f
    For redundancy I measure 1.86 Ko
    3K  0
    manual · 2G DSM
    1K  0
    Loading...
    miguelmcv likes this.
  7. 1990TSIAWDTALON
    7,094
    3,256
    Joined Nov 14, 2013
    I say for sure that the CTS is not a problem on your car, that is pretty cut and dried.
    Street Build 5K  31
    2K  15
    992  18
    Street Build 1K  7
    Loading...
    miliman13 likes this.
  8. miliman13
    1,957
    274
    Joined Jan 1, 2011
    tampa, Florida
    image.jpg image.jpg Looks as good as day ecmlink did maintenance on it ....
    3K  0
    manual · 2G DSM
    1K  0
    Loading...
  9. greddy_1700
    955
    41
    Joined Aug 27, 2006
    Regina, SK, Canada
    Being that you mentioned speed density, I assume you have verified that both the IAT and MAP sensors are working properly in link?
    Also, stupid question, but just to rule it out, all of your settings in Link are still uploaded to the ECU? Just confirming that link didnt somehow reset to factory, and that its expecting speed density, plug wire inversion, etc?
    1990TSIAWDTALON likes this.
  10. Vegas Smith
    Vegas Smith Proven Member
    4,133
    1,959
    Joined Dec 2, 2002
    Houston, Texas
    Can you post a log?
    Street Build 4K  4
    1993 Eagle Talon TSi AWD
    Loading...
  11. miliman13
    1,957
    274
    Joined Jan 1, 2011
    tampa, Florida
    So I ran a test
    Unplugged all the injectors
    And jumped the circuit in the starter from engine bay while spraying starting fluid into a vac line...
    It ran rough
    So I had another idea..
    I disconnected my fuel line from the filter and then held it up and injected brand new gas ethanol free I use for my tractor into the line.
    Of course I disconnected the fuel pump as well..
    With a syringe amount of gas that I injected into the fuel line ; it instantly ran...
    Meaning that the gas has gone bad..
    Or it’s bad gas idk....
    And I thought wawa was legit
    So in conclusion it was intact the gasoline that was preventing the car from igniting and idleling..
    3K  0
    manual · 2G DSM
    1K  0
    Loading...
  12. miliman13
    1,957
    274
    Joined Jan 1, 2011
    tampa, Florida
    Nope drained gas put new in;
    Starts for a few secs and dies w/3
    Cool lawn ornament I guess .
    3K  0
    manual · 2G DSM
    1K  0
    Loading...
  13. ThunderChild
    ThunderChild Supporting VIP
    3,750
    1,099
    Joined Jan 5, 2012
    Rathdrum, Idaho
    Have you verified you have good and proper fuel pressure/flow? Also, are you're injectors possibly shelacqued from sitting so long?
    Street Build 1K  3
    1990 Plymouth Laser N/T
    fwd · manual · 1G DSM
    976  8
    1987 Toyota Pickup/Hilux
    awd · manual · Misc Vehicles
    Street Build 2K  7
    1997 Mitsubishi Eclipse Spyder GST
    2K  0
    manual · 1G DSM
    Street Build 3K  10
    Loading...
  14. motomattx
    motomattx Proven Member
    3,224
    1,154
    Joined Dec 9, 2010
    wampum, Pennsylvania
    I had critters crawl up inside my muffler overnight one time and cause a no start, took me a week or so to figure that one out, try pulling your o2 sensor just for the heck of it and see if it tries to run.
    Drag Race Build 4K  10  24
    1995 Mitsubishi Eclipse GST
    Loading...
    miliman13 and 1990TSIAWDTALON like this.
  15. pauleyman
    pauleyman DSM Wiseman
    6,218
    1,525
    Joined Nov 19, 2011
    oklahoma city, Oklahoma
    How did you verify fuel. I dont think you're getting any. If it ran the day before it isnt the gas
    Street Build 4K  1
    1997 Eagle Talon TSi AWD
    awd · manual · 2G DSM
    Loading...
    1990TSIAWDTALON and ThunderChild like this.
  16. jakk220
    jakk220 Proven Member
    1,274
    277
    Joined Nov 13, 2010
    Akron, Ohio
    Sounds like a pump issue if it ran when you put gas in it at the fuel filter line. Are you 100% sure that your pump is kicking on and getting fuel to the rail?
    748  1
    1991 Mitsubishi Eclipse GSX
    2K  3
    1997 Mitsubishi Eclipse GSX
    Street Build 2K  1
    1993 Mitsubishi Eclipse GSX
    Loading...
  17. 1990TSIAWDTALON
    7,094
    3,256
    Joined Nov 14, 2013
    Fuel pump rewire fuse??
    Street Build 5K  31
    2K  15
    992  18
    Street Build 1K  7
    Loading...
  18. miliman13
    1,957
    274
    Joined Jan 1, 2011
    tampa, Florida
    9A576D70-1F16-4069-BB47-0094406EADCB.jpeg 6BF2859D-3411-4F2A-9D50-5704FB7032A9.jpeg For the above questions
    Yes I have fuel flow and pressure
    I have sensors that log on link
    I have also seen it with my own eyes
    When I had to drain the whole tank
    This bottle filled up in the time it took me to look up and shut off pump from link
    It has a few times actually reved
    When playing with throttle at crank
    But shuts down right after ....
    I can’t keep it on .
    3K  0
    manual · 2G DSM
    1K  0
    Loading...
  19. Vegas Smith
    4,133
    1,959
    Joined Dec 2, 2002
    Houston, Texas
    A log could be helpful to double check settings and such.
    Street Build 4K  4
    Loading...
  20. tsiawd90
    tsiawd90 Supporting Member
    99
    21
    Joined Nov 16, 2017
    Houston, Texas
    If you have fuel to the rail, spark, and you have verified ignition timing, I would look into the injectors. Check the connectors and pull injectors and have them cleaned.
  21. miliman13
    1,957
    274
    Joined Jan 1, 2011
    tampa, Florida
    thanks everyone sorry its taken so long, im back again trying things like a mad man.
    i swapped out the starter and MPI relays out; Nothing........
    she still cranks, but wont ignite and stay on .
    if i floor it while cranking it will idle for seconds at a very low rpm .
    im hoping someone has any similar experiences....
    3K  0
    manual · 2G DSM
    1K  0
    Loading...
  22. miliman13
    1,957
    274
    Joined Jan 1, 2011
    tampa, Florida
    Have been using link to
    Check the functionality of my sensors
    It is very useful.
    3K  0
    manual · 2G DSM
    1K  0
    Loading...
  23. 1990TSIAWDTALON
    7,094
    3,256
    Joined Nov 14, 2013
    This is sounding more like a tune issue as mentioned earlier. Check your global and deadtimes, injector offsets, etc. Just to be sure something doesn't look funny. What is the wideband telling you for fuel? Rich, lean, cant tell?
    Plugs wet/dry or fouled after attempting to start?
    Street Build 5K  31
    2K  15
    992  18
    Street Build 1K  7
    Loading...
  24. miliman13
    1,957
    274
    Joined Jan 1, 2011
    tampa, Florida
    Nope
    It’s the same settings as before
    I’ve keeped logs for comparison .
    Plugs are fine ; and new as well
    Again the car can’t idle more than 3-5 seconds at max
    Not enough time for any data to be meaningful.
    Even tried a new CAS even though I never suspected it ...
    Not gonna lie in all my years this one event has had me down longer than anything before.
    When you build your car from ground up , you become very familiar with it.
    And in the past it’s taken me minutes to resolve issues ...
    Not this time .....
    3K  0
    manual · 2G DSM
    1K  0
    Loading...
  25. boostdawd
    boostdawd Supporting Member
    1,450
    325
    Joined Apr 6, 2010
    phoenix, Arizona
    How did u verify spark? U may be getting it on all cylinders but may be weak ok some. I had this happened on my talon. Spark was present on 2,3 but not as bright as 1,4. Coils were in spec. Swapped different coil packs on 2,3 for the heck of it and ran great afterwards. Mine was experiencing similar issues as yours.
    Street Build 1K  1
    awd · automatic · 2G DSM
    Drag Race Build 5K  10
    1991 Eagle Talon TSi AWD
    manual · 1G DSM
    Loading...
Share This Page
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
