1. Join the Community!
Crank contact with CAS
Posted by BLACK'98DSM, Nov 11, 2019
Please Support VR Speed Factory
Please Support Feal Suspension
  1. BLACK'98DSM
    BLACK'98DSM Proven Member
    1,039
    335
    Joined Feb 9, 2019
    Hoover, Alabama
    Is the crankshaft supposed to rub against the CAS? When I changed the CAS I noticed that it had some material missing, due to being in contact the the crankshaft. From my understanding the crankshaft is supposed to be a couple millimeters off the sensor?
    Road Race Build 2K  25
    1998 Mitsubishi Eclipse N/T
    fwd · manual · 2G DSM
    390  3
    2012 Murray Explorer Dune
    rwd · automatic · Misc Vehicles
    297  6
    2009 Troy Bilt Bronco
    Loading...
  2. dsmcrzy
    dsmcrzy Proven Member
    1,140
    226
    Joined Dec 20, 2009
    Trenton, Ohio
    It’s supposed to have space. Where did you get it from? The only place I have had luck with besides OEM has been NAPA. Anywhere else (autozone, advance, etc) they are too long, or too short. There are a few threads on this site documenting it. It’s also been my own personal experience.
    Street Build 4K  12
    1996 Mitsubishi Eclipse N/T
    Loading...
  3. BLACK'98DSM
    1,039
    335
    Joined Feb 9, 2019
    Hoover, Alabama
    I thought so.
    It was the stock one. That's concerning, if the stock one rubs then something must be wrong? I can check the new one to see if it is rubbing too, but when I compared them they were the same lengths so it most likely is.
    390  3
    297  6
    Loading...
  4. silvreclips
    silvreclips Proven Member
    1,025
    200
    Joined Jul 19, 2005
    Greenville, South Carolina
    I have multiple crank sensors in my spare parts box and all of them show signs of contact right on the tip. Not really sure why but it must be normal.
    Autocross Build 229  1
    Loading...
    VelocitàPaola and BLACK'98DSM like this.
  5. Macgyver'sDSM
    Macgyver'sDSM Proven Member
    89
    31
    Joined Feb 20, 2017
    On the lake, Wisconsin
    Check the end play on your crank. If the thrust bearings get worn [ crank walk ] your crank can make contact with your crank sensor.
    Street Build 2K  10
    1995 Eagle Talon TSi
    awd · manual · 2G DSM
    Loading...
    BLACK'98DSM likes this.
  6. VelocitàPaola
    VelocitàPaola Moderator
    4,896
    109
    Joined Jun 14, 2005
    Ft. Lauderdale, Florida
    Are you thinking of the 4G63? Crank walk hasn't been a big concern with the 420A engine, and the 420A's crank sensor is perpendicular to the crank's axis or rotation, so a thrust bearing failure wouldn't bring the crank any closer to the sensor.
    1K  21
    1995 Mitsubishi Eclipse N/T
    manual · 2G DSM
    Loading...
  7. Macgyver'sDSM
    89
    31
    Joined Feb 20, 2017
    Yes 4g63 sorry didn't catch the 420a
    Street Build 2K  10
    Loading...
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
