Enigma_Man
- 937
- 0
- May 15, 2002
Lawrence,
Massachusetts
Okay, so I have a Lotec 3 gauge A-pillar pod, and just a boost gauge. I have some questions about stuff.
1) When you mounted your pod, did you cut away the plastic interior trim, and use the pod to replace it, or just screw it onto the top of it?
2) If you did screw it onto the top of it, how/where did you run the power/tubing down to the dash?
2a) If you did cut away the plastic interior trim, where/how did you run the wires/tubing?
3) The plastic tubing they give you sucks. Mine got squished where I had it going down behind the dash (just sorta shoved it down a crack) and now it's permanently squished, and reports vacuum incorrectly. What would be a good replacement for the shoddy plastic tubing?
4) Maybe I'm lazy, or couldn't find it or whatever, but I had a real hard time finding a way to run the hose to the engine bay. I ended up putting a hole through the steering column boot through the firewall, and just shoving it through there. I'd like to find a more permanent/better spot. Anybody know of any good locations / what I gotta take apart to get to them?
Thanks a ton in advance guys
-Jesse
-Jesse
