cooling fan problems
92fwdtsi
Nov 28, 2002
when my engine temperature reaches normal the cooling fan suppose to kick in but it doesn't. Instead it slowly goes past normal about 3/4 of the way but it doesn't reaches hot. The needle pretty much just stays there. I replaced the fuse already but after about 24 hours later it blew up again. A friend of my brother told me to unplug the cooling fan, put a new fuse in and see what'll happen. About a couple hours later the fuse blew and my brother's friend told me its not the fan. The thermostat and water has been replaced. So what could be the problem? And how much do the parts cost? Is there way to troubleshoot the problem?
if you look in your shop manual it'll have procedures for troubleshooting the cooling fans. i believe there's a relay in the black box in the engine compartment on the drivers side you can take out, jump 2 connections, and check that both fans come on. if they both run i believe you can try replacing the relay, or checking the temp sensors. if you haven't already, just spring for a shop manual. you don't absolutely have to have the manufacturer's book, and you'll easily save enough time to justify the $15-20 you spent.
  • Wanted 1g WTB. DSMlink V3 eprom chip
    I'm looking to purchase a 1g dsmlink chip.
    • 92GVR4SC
  • For sale 1995 Mitsubishi Eclipse GSX AWD for sale
    Modified 1995 Mitsubishi Eclipse GSX AWD
    • 95_gsx
  • For sale Dynatek ARC-2
    Dynatek arc-2
    • FWD
  • For sale 2g Haltech elite 1500 setup
    Up for grabs this Haltech Elite 1500 with Haltech wideband complete with sensor and CAN...
    • GST2012GSX
  • For sale 4G63 Apexi SAFC
    Apexi SAFC $185 + shipping and PayPal feesYou must be registered to see element.
