chrisman287
- 1,146
- 1,074
- Jul 19, 2021
New York
When I bought my car the engine bay fuse box was relocated to the passenger side airbag spot and the aftermarket (look like eBay) fans were on a separate switch. I’m looking to drive the car more and don’t want to worry about monitoring coolant temp and turning the fans on and off myself.
I got better fans and this coolant temp sensor relay kit. I’m wondering if I can use this fitting on the thermostat housing rather than the supplied hose adapter?
If I can’t, should I cut the upper or lower hose to fit the adapter? I’m thinking lower.
Engine bay fuse box is in the passenger side airbag spot and all the wiring is there in the right kick panel. I have messed with it before just redoing all of the crimps/solders to prevent the possibility of future issues but it’s a mess.
