1. Join the Community!
Compression test
Posted by victors_97dsm, Nov 11, 2019
  1. victors_97dsm
    victors_97dsm Probationary Member
    21
    3
    Joined Aug 28, 2010
    sierra vista, Arizona
    Just did my annual compression test and it seems like cylinder 2 has been the weak one so far. The block internals are still factory with the exception of a new head gasket. This car has never been raced on a track (learned my lesson from my GS-T)
    I am the lucky 3rd owner which seems to care for it more than others
    I try to upgrade small things here and there but the engine will have to wait until it goes under the 133 service numbers on the cylinders
    SasaniFab and buddahboost like this.
  2. motomattx
    motomattx Proven Member
    1,918
    675
    Joined Dec 9, 2010
    wampum, Pennsylvania
    I wouldn't be overly concerned with those numbers.
    Drag Race Build 3K  24
    1995 Mitsubishi Eclipse GST
    fwd · manual · 2G DSM
    Loading...
  3. buddahboost
    buddahboost Proven Member
    332
    50
    Joined Aug 15, 2007
    CHICAGO HEIGHTS, Illinois
    Keep up the good work. Always happy to see someone taking care of their car.
    Are you on a stock ECU? If so, does your car stumble when coming to a stop or shifting gears? Asking because of the non recirculated blow off valve
    And I would change that filter on the left side of your valve cover to a line that goes to your intake pipe. You can put one of those lawn mower see thru filters on there if you want a filter
  4. silvreclips
    silvreclips Proven Member
    1,026
    203
    Joined Jul 19, 2005
    Greenville, South Carolina
    Was the motor cold or warmed up?
    Autocross Build 229  1
    1998 Mitsubishi Eclipse N/T
    Loading...
    BLACK'98DSM likes this.
  5. Vegas smith
    Vegas smith Proven Member
    2,791
    1,348
    Joined Dec 2, 2002
    Houston, Texas
    Those numbers aren't bad.
    Street Build 3K  10
    1993 Eagle Talon TSi AWD
    awd · manual · 1G DSM
    Loading...
  6. tk106
    tk106 Supporting Member
    1,770
    496
    Joined Sep 11, 2017
    Cincinnati, Ohio
    I'd be ecstatic with those numbers.
    169  3
    2000 Jeep Cherokee Sport - Classic
    awd · automatic · Misc Vehicles
    172  4
    93 Civic 4 Door -sold-
    fwd · manual · Misc Vehicles
    Street Build 2K  6
    1992 Eagle Talon TSi AWD
    12.625 @ 111.42 · 1G DSM
    Loading...
  7. BLACK'98DSM
    BLACK'98DSM Proven Member
    1,040
    337
    Joined Feb 9, 2019
    Hoover, Alabama
    Are yours lower?
    Road Race Build 2K  25
    390  3
    2012 Murray Explorer Dune
    rwd · automatic · Misc Vehicles
    297  6
    2009 Troy Bilt Bronco
    Loading...
  8. tk106
    1,770
    496
    Joined Sep 11, 2017
    Cincinnati, Ohio
    120 110 110 110 cold. I know I know LOL
    169  3
    172  4
    Street Build 2K  6
    Loading...
  9. BLACK'98DSM
    1,040
    337
    Joined Feb 9, 2019
    Hoover, Alabama
    I was about to point out how my numbers are 70-80 psi higher than yours, but then you could turn around and make fun of my 420a. LOL. Hey, at least it still runs!!! :thumb:
    390  3
    297  6
    Loading...
  10. tk106
    1,770
    496
    Joined Sep 11, 2017
    Cincinnati, Ohio
    She runs good and surprisingly doesn’t smoke either. Just low power before getting into boost. Used to be 120 90 90 110 before I refreshed my head. I’ll get to new rings somewhere down the road.
    169  3
    172  4
    Street Build 2K  6
    Loading...
  11. kenuwine4g63
    kenuwine4g63 Proven Member
    462
    28
    Joined May 26, 2009
    Charlotte, North Carolina
    Do you have cams and adjustable cam gears? If so, your issue is fairly easy to correct. You may have some overlap where one of your valves are opening early.
    kenuwine4g63
    390  0
    000.0 whp · 000.0 lb/ft · 2G DSM
    Loading...
  12. tk106
    1,770
    496
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Stock cam gears. Had stock cams before the head refresh. Installed Kelford 272’s when putting it back together.
    169  3
    172  4
    Street Build 2K  6
    Loading...
  13. kenuwine4g63
    462
    28
    Joined May 26, 2009
    Ohhh yes. Once you dial them in your compression numbers should go back up.
    kenuwine4g63
    390  0
    Loading...
  14. EVLGSX
    EVLGSX Proven Member
    440
    171
    Joined Dec 7, 2017
    Wallingford, Connecticut
    Throw that breather filter in the trash and put the line back that went from VC to pre turbo. Then find a way to recirc that BOV.
    edit: 2 air meters?
    Street Build 2K  15
    1997 Mitsubishi Eclipse GSX
    awd · manual · 2G DSM
    Loading...
  15. tk106
    1,770
    496
    Joined Sep 11, 2017
    Cincinnati, Ohio
    That’s a tial q Evl. Can’t recirc it. Agree on the breather.
    169  3
    172  4
    Street Build 2K  6
    Loading...
  16. motomattx
    1,918
    675
    Joined Dec 9, 2010
    The pressure differential between cylinders is much more telling than a static compression number itself, in fact on a modified engine compression numbers are almost null and void and for reference purposes only.
    Loading...
  17. EVLGSX
    440
    171
    Joined Dec 7, 2017
    Street Build 2K  15
    Loading...
  18. tk106
    1,770
    496
    Joined Sep 11, 2017
    Cincinnati, Ohio
    I learned something new today.
    169  3
    172  4
    Street Build 2K  6
    Loading...
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
