FORMONTOYA
DSM Wiseman
- 2,259
- 57
- Oct 7, 2004
Houston,
Texas
ok...doing a turbo swap and after removal of the exhaust mani i found that i need to yank the head for a freshen' up (#2 & 3 exhaust port is coated in oil, bla, bla, bla...). so before i remove the head i want to get an idea of how the bottom end is holding up. ran strong until the turbo took a dive...but hindsight is 20/20...and after a few searches through various forums, the head has probably been going out for about 4+ months before the turbo dumped (used to the old v8...exhaust would have looked worse w/bad seals, does the turbo mask this a little...humm). anyway i want to do a compression check...
1) how important is it to have the car totally warmed up? car is up on 4 jackstands now w/exhaust mani setting on garage floor.
2) are there any cold numbers that i should hit, or a percentage to add since it is cold (cold rings should give a lower number...and get better when warmed up...right?)? i do not want to fire it up w/no exhaust mani. and would have to do a lot of work just to get it drivable again...to just turn around and tear it apart right after.
3) what are my options?
doing a search revealed this site:
http://www.geocities.com/dsmgrrrl/FAQs/compression.htm
thanks,
jim
thanks,
jim
