whiteclaw95
- 50
- 0
- Aug 23, 2012
Lake Mills,
Wisconsin
I did the key dance and came up with code 12 and code 43.
Ill start with code 43. in my Haynes manual it says this code is a misfire on one or more cylinders. Spark plug, injector, cylinder compression or air intake problem.
According to http://troublecodes.net/mitsu/ this code is an egr fault. Dont know which is correct do you???
Code 12 is not listed in my manual. After looking at http://troublecodes.net/mitsu/ I found out this code is for an airflow sensor which I have no clue which sensor that is where I have a map and not a maf.
Any help to shed the light will be helpful thanks guys
