Scoobystyl
- 277
- 1
- Nov 5, 2011
Denver,
Colorado
I'm not really sure where this should be posted but I've read multiple threads trying to figure out why the car would die everytime the clutch was pressed in and from what I saw nobody was able to figure out a fix, a lot of different opinions were thrown around like adjusting your BISS screw, checking your IAC position, plugs/wires, vacuum/boost leaks, and while all of these are good things to check and could play a part. However in my case everything was perfect but I replaced the PCV valve today and no more clutch issues.
In short if everything is in order and your still having issues with your car dying, try replacing your PCV valve.
