ricecooker
- 0
- Jun 5, 2002
orlando
Ok i have a 1990 eagle talon tsi fwd.
i changed my clutch , slave cylinder and master cylinder .So everything is new, however i have a major problem.First the clutch pedal is all the way to the ground .i kinda fixed that by pushing the lever from the transmission case out and letting someone pump the pedal till the rod from the slave cylinder pushes out and meets the lever all the way.whenever i do this the clutch pedal gets hard but the is still some play in it.However the clutch now is always engaged and the boost builds and revs build but the car feels like the clutch is slipping. Other than that if i dont push the rod all the way out the clutch total is engaged and the pedal stays all the way to the floor.
Well i think it might be my release bearing(throw out bearing).
Please help me to figure this one out.
thanx for your help guys
