Clutch problem!
eXploitedGST
289
Jul 27, 2002
Alright... awhile back... (like 4 months ago) i pulled my transmission out of my 91 awd.... and when i put it back together and started it the bellhousing had the most aweful sound come out of it and the clutch wouldnt disengage.... finially i got around to pulling out the transmission agian just yesterday... and after looking at it i still see nothing wrong! the only thing i questioned was when the had the pressure plate tightened down the diaphram springs were not sticking up at all.. there were already flattened down and i thought they had to stick up a little when the clutch was engaged... any ideas or what might be the problem here? o yea... my bellhousing thats on there was cracked from top to bottom then welded shut before i got the car.... would that affect anything like this?
haha sounds like you bought the car from the same person i did:D well i have a similar problem my clutch is always engaged and well im pretty sure its the pressure plate so im just going to pu tina new clutch setup and see what happens...Im just going to start rreplacing things until it works:rolleyes:
  • For sale 1g 1g rear strut brace. RRE made.
    Original RRE made rear strut brace or bar. Bolt in. Fairly lightweight also. Good for an...
  • For sale 2g 2g GSX downstream Denso 02 sensor
    2g GSX downstream Denso 02 sensor. New. OEM quality. Price is shipped in a USPS flatrate...
  • For sale 2g 2g mirror covers, etc
    2g mirror covers. Need some glue work on bottom. Difficult to find. Good condition otherwise...
  • For sale Coilover springs
    2.5" inner diameter, 7in long coilover springs. I believe the spring rate is 10kg...
  • For sale 4G63 MHI Small 16g Compressor Housing
    MHI Small 16g Compressor Housing $65 + shipping and PayPal fees* this turbo had shaft play and...
