1. Join the Community!
Clutch Problem?
Posted by Pozobyt, Oct 24, 2010
Please Support RTM Racing
Please Support Southbay Fuel Injectors
  1. Pozobyt
    Pozobyt Proven Member
    177
    Joined Jun 22, 2010
    lucedale, Mississippi
    I just did a auto/manual conversion, and the car ran flawlessly the first few days, now all of a sudden, I can't get the car into gear with the car running. when the car is off, it goes into all gears very easily. the clutch feels fine, and I can watch the slave cylinder and it has the same ammount of movement as before when the clutch is engaged.(if that makes sense) I used a brand new oem clutch and throw out bearing. sometimes if I try to get it into first, it grinds slightly, even with the clutch pedal pressed to the floor. I only bled the slave after I put the transmission in, but the car ran fine for the first few days, so I wouldn't think I'd need to bleed it again, since it was just running fine.
    I can start the car in first with the clutch engaged, and it's will run in first just fine, but still wont shift to second.
    it is a 99 eclipse.
    438  0
    1999 Mitsubishi Eclipse N/T
    · 2G DSM
    Loading...
  2. ninja07
    ninja07 Proven Member
    51
    Joined Dec 7, 2009
    antioch, Tennessee
    Adjust shifter linkage. Check clutch master rod adjustment. Good luck. Hope it fixes it.
    272  0
    1995 Eagle Talon TSi AWD
    manual · 2G DSM
    Loading...
Share This Page
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
