Eclipse2630
- 172
- 0
- Dec 8, 2011
Fort Stewart,
Georgia
Hey guys bare with me on this, I have searched and searched but didnt quite find an answer, so here is the situation in the best description possible. I had a ACT unsprung go bad, So i replaced it with a ACT 6 puck sprung clutch, ACT pressure plate and a fidanza FW with a Mitsu OEM TOB. after install we bled and bled and adjusted the best we could the same way we have done before, well with my car, When u push in the clutch on any other manual car all the way, it goes til it stops and will not go any farther, well mine, you push it until it stops and still has a good maybe inch and a half to 2inch distance from the floor. When you get the pedal to its "stopping point" if you push a little harder it will travel and extra inch but is very very stiff and basically feels like you are pushing against a stiff spring. Im not sure if the pivot ball needs shimmed or bent clutch fork. Or maybe we just messed up this one time and didnt adjust it correctly. I hope maybe someone out there had this issue and can chime in! I did notice my clutch pedal does click when pushed so im pretty sure i need a new Master but i dont think it would cause my main issue! please help!
anyone?
anyone?
