clutch pedal doesnt have pressure
dohcGST
48
Dec 15, 2003
Charlotte, North Carolina
so im driving home last night and i was pulling out from a stop light and the clutch pedal all of a sudden went out. and there wasnt enough pedal to get the car to change gears, so i had to 2nd gear it all the way back home.
i just rebled it 3 times and there is still no clutch pedal...there is a little bit of pressure towards the bottom of the pedal, but still not enough to get it going.
i just put a brand new slave and master cylinder on it 3 weeks ago, and the master cylinder hasnt lost any fluid either.
what the hell is wrong???????????
i have adjusted them. it just all of a sudden lost pressure last night.
the clutch fork isnt bent, its been rebled this morning (no air in it), no leaks inside or out.
check ## clutch master cylinder fluid
i just replaced the slave cyinder, and it didnt help any....
it only did this while i tried to shift fast. any ideas of what would cause it? there aren't any leaks there isnt any air in the system.
clutch master cylinder and slave cylinder is different
i've checked over everything. and i just rebled it again with the new slave cylinder, i was told thats the problem so i replaced it
it did NOT lose any fluid last night when it went out. which im thinking rules out the master cylinder, im going to try to adjust the master cylinder in the morning to see if anything happens.
this is in a 93 TSi FWD also, it wont let me change the user profile?
