jake1337
- 0
- Feb 12, 2014
Auburn Hills,
Michigan
Need help diagnosing woosh/wurr/dragging noise when clutch pedal is pressed. The noise is also present while cruising at any speed/gear.
You can hear it when the pedal is slightly pressed and also when all the way in.
Pics and videos are attached.
I disconnected the slave and put pressure on the fork with my hand, still makes noise. Car seemed to shift normal, clutch not slipping and disengages without issue.
My set up is a new OEM master and slave, SS clutch line, stock flywheel at .610" step height, Southbend daily stage 2, comp clutch fork and ball, OEM TOB, 2 washers shimming the pivot ball, fork in the middle of the window. MT90 for the oil. ARP flywheel bolts with red loctite at 100lbs and the pressure plate bolts at 25lbs.
Clutch has been adjusted for most travel according to Jack's Transmission. Master out far enough to block the slave, then adjusted half turn until the slave can be pushed back in. I assumed I was over extending, so adjusted pedal inwards A LOT and still getting the same noise as when it's adjusted for max travel.
I'm at a loss and I really need a working car.
Thanks in advance.
Thanks in advance.
