Zufelt
- 533
- 9
- Oct 15, 2012
Lemoore,
California
hey guys I'm currently having a clutch problem I have a2g GSX with an act 2600 clutch and resurface flywheel which is about a year old. From the beginning I was having problems getting my car into gear if I adjust the clutch properly I can get into a gear and drive but if I went wide open throttle I can shift until my RPM's dropped. so I just did so I could get into gears and not slip but it was then not adjusted properly. So now a year later it's starting to slip on me but there isn't any smell of clutchbut if I adjust it properly I have the same shifting problems and it doesn't slip. I should also mention that I got an OEM slave when the clutch is replaced along with new OEM hardware but unfortunately I didn't have enough to replace the Master as well. My thought is that the master cylinder isn't pushing enough fluid to allow me to shift at high rpm when adjusted properly I can't see any external leaks but figure it's more than likely in need of relacement since it's probably the same stocker so the 2600 finished it off.. any opinions would be great I don't wanna drop money on a hunch I have.
