cait sith
20+ Year Contributor
- 2,039
- 13
- Nov 22, 2002
Brooklyn,
New_York
After having my clutch die, I put in another clutch (OS Giken), pivot ball (OEM), slave cylinder (OEM), TOB (as provided with the clutch) and I visually checked the centerline with no slave on the clutch fork, and it looked exactly like the RRE photo (ie: Centered in the window).
NOW– Here's my issue: Post install of the new slave, bleeding the system, etc, the clutch fork is slightly pushed over (approximately 3 or 4mm or so) to the passenger side. The last owner of my car had an extended slave cylinder on the car and it lead to pedal pump up issues and the eventual destruction of my other twin disc. I really, really don't want this to happen again, so I'm trying to make everything perfect. I do not have an extended slave rod on the car.
Also, should the TOB always be in contact with the clutch? I'm guessing yes, but wanted to confirm. While seeing the clutch spinning I can see the TOB spinning through the fork window.
I adjusted it per the jack's transmission video, I don't feel any clutch pump up at all like I did previously. Engagement feels clean and smooth. I haven't had a chance to road test it yet because I broke my ECU temp sensor putting the starter back in, and I'd like to have this transmission issue sorted out while it's still on jack stands.
I'm thinking this feels/sounds like a hydraulic adjustment issue.
If I have to drop the transmission again, I'm going to drive this car off a cliff.
