1. Join the Community!
Clutch bleeding problems
Posted by Darin Shaw, Nov 18, 2019
Please Support STM Tuned
Please Support VR-Speed Factory
  1. Darin Shaw
    Darin Shaw Probationary Member
    Joined Nov 18, 2019
    Brewster, Ohio
    My buddy has a 01 Chevy Silverado 1500 4.3l 5sp. After owning it for a month or so the clutch went out or so they thought. A certified diesel mechanic said he needed a new master cylinder when the problem was fluid leaking where the line comes out of the master cylinder.
    They purchased a new master put it in but didnt hook anything up. Another certified diesel mechanic pulled the new master out and tore it apart saying it needed rebuilt. Put it back together so on and so forth. I have rebuilt it 6 times now everything seems to be working.
    When I bleed and prime the master no matter how many time I do it it still pushes air thru the lines. Never stops. Hook everything back up and it will build pressure to an extent then act like there is air in it and go back to a spongy pedal any suggestions? They also spiced the line from high pressure rubber to steel line back to rubber with compression fittings. Any tips would be useful. Last thing I have to try is running full steel line from master to slave.
  2. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    4,538
    1,974
    Joined Nov 14, 2013
    Independence, Kansas
    Darin, you could get a -3an or -4an stainless braided line and go directly from the master to the clutch slave cylinder, compression fittings are NOT a good thing on hydraulic lines (especially BRAKE lines, your clutch is a lot like a brake system). It almost sounds like an internal leak in the master allowing air in. When they rebuild the master, do they hone the bore or just replace stuff like it will magically work?
    Marty
    Street Build 3K  27
    1992 Eagle Talon TSi AWD
    awd · automatic · 1G DSM
    508  14
    1990 Mitsubishi Eclipse GSX
    awd · manual · 1G DSM
    440  18
    1967 Chevrolet Camaro RS
    rwd · automatic · Misc Vehicles
    Street Build 636  4
    1998 Eagle Talon TSi
    fwd · manual · 2G DSM
    Street Build 5K  11  25
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 · 1G DSM
    Loading...
  3. Darin Shaw
    Joined Nov 18, 2019
    Brewster, Ohio
    The master was brand new didnt need anything to begin with but someone thought they knew what they were doing and tore it apart anyhow not knowing anything about them. When bleeding/ priming the master if you push the pedal very slowly it will push fluid with no air. But if you push the pedal down normal pace or what not you get an air pocket thru the line.
  4. Darin Shaw
    Joined Nov 18, 2019
    Brewster, Ohio
    The master and the slave both where the line goes in are both a nipple like a brake bleeder nipple held in by a pin. Thats where the problem and everything started was started to leak around that nipple. He does not have a job at the moment So I have tried the next best thing which was to remove the nipple period. No matter was seal or o ring wr tried it always started leaking again so I jb welded a compression fitting inside the hole sealed great no leak. The braided line from the factory has a rubber line inside. No leaks are present in the steel lines just where they go to the rubber line on the compression fitting. Dont know whats going on. And lastly pulled the transmission today to check slave and clutch itself clutch is perfectly fine dont know how to check the slave but there was a ton of break fluid laying in the bottom of the ball housing. Dont know if the slave is leaking or if it is coming from when I crack the bleeder
  5. 1990TSIAWDTALON
    4,538
    1,974
    Joined Nov 14, 2013
    A lot of miles on that vehicle? My 87 IROC has a hydraulic clutch and it sounds very much like yours with the pin, a PLASTIC line and an oring to hold it in the slave. I change these DSM cars over to a single braided line all the way from the master to the slave and when (an if) I get the IROC running again, I will see if I can retro it. It is on its 2nd set of masters and slaves, they only sold it all in a kit so I had to buy the whole thing.
    Street Build 3K  27
    508  14
    440  18
    Street Build 636  4
    Loading...
  6. BLACK'98DSM
    BLACK'98DSM Proven Member
    990
    318
    Joined Feb 9, 2019
    Hoover, Alabama
    Just curious how you came across DSMTuners for a Chevy Silverado? LOL
    You're welcome here anyway, I'm just curious!
    Road Race Build 2K  25
    1998 Mitsubishi Eclipse N/T
    375  3
    2012 Murray Explorer Dune
    293  6
    2009 Troy Bilt Bronco
    Loading...
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
