Stevestalon
- 6
- Sep 7, 2019
Saint Petersburg,
Florida
Anyone have a link to a check valve they use in between their IM and pcv? Or a pcv valve that doesn’t leak...
Note: This feature currently requires accessing the site using the built-in Safari browser.
HERE is the ones I use, they work great..shipping takes a lil bit but they're good quality and tested great. Otherwise the kynar check valves work for many other members.
If you are looking for a Mitsubishi OEM, the part number is MD024719.
https://www.extremepsi.com/store/OEM-PCV-Valve-Mitsubishi-Eclipse-90-99.html
I used to have the check valve in the link below between the OEM PCV valve and the intake manifold, and also used as the brake booster check valve. It was working well for many years.
https://www.ebay.com/itm/3-8-HB-Kyn...601957?hash=item19eb2a5325:g:1pcAAMXQyY1TQEDt
Thanks for your inputs, I went ahead with the kynar one from us plastics.I ran a check valve that I found from us plastic Corp back in the day.
