Snake
- 70
- 0
- Mar 26, 2003
Ok finally I was able to pull the trouble code from my car.
It was a 1400 DIFFERENTIAL PREASURE SENSOR OUT OF RANGE.
Ibelive this is the MAP SENSOR(manifold absolute preasure sensor) located in the top of the INTAKE MANIFOLD
Now for some reason on the turbo models the correct name is MDF (manifold diferential preasure)
I now that the samrt thing to do is to
-Check the o ring
-Check for a broken or lose conector
-The troble shoting guide on the scaner also sugested a PCM failure but I seriosly dout that because my car runs great!
Now has anyone around here had this code before??
Could there be something else besides the MDF to cause a this error code???
What else could I look for??
I youst want to be sure that the MDF is faulty before I buy it
Thanks in advance
-Check the o ring
Thanks in advance
