1. Join the Community!
Changed the intake manifold gasket on my 95 talon tsi and it won’t start after, HELP
Posted by TreWebbDSM, May 25, 2020
Please Support ExtremePSI
Please Support Southbay Fuel Injectors
  1. TreWebbDSM
    TreWebbDSM Probationary Member
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
    So I swapped the intake manifold gasket out, copper sprayed the gasket itself, the egr gasket, and the throttle body gasket. I put everything back together on the car and it will crank but not start for over a second. I left my food floored on the throttle and it still would sputter and die and I have no clue what could’ve gone wrong
  2. TreWebbDSM
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
    My mods are 750cc injectors, 14b, walbro 255, vrsf fmic, egr vac lines blocked off, Halman mbc, ngoni bpr6es, ecmlink v3
  3. TreWebbDSM
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
    It also ran and I daily drove it before this happened but it did have a leak at the intake
  4. Sjd6795
    Sjd6795 Proven Member
    422
    101
    Joined May 14, 2014
    Wilsonville, Oregon
    Well if you copper sprayed everything you could've got it where it doesnt belong. And also there isnt any reason as to why you would need to put copper spray on your gaskets especially on the intake manifold. Brand new gaskets and making sure the surface is clean then following torque should seal it off.
    How long did you wait before starting the car after getting it all back together? The sealant needs time to setup, also is every sensor and vacuum lines connected back correctly? Do a boost leak test to make sure there is no leaks.
    Street Build 491  11
    1997 Mitsubishi Eclipse GSX
    awd · manual · 2G DSM
    Sjd6795
    Street Build 1K  0
    1991 Eagle Talon TSi AWD
    manual · 1G DSM
    Loading...
  5. TK's9d2TSi
    TK's9d2TSi Supporting Member
    3,083
    1,198
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Check your work and make sure all connectors are secure. Check firing order for plugs too. Has to be something simple
    379  3
    2000 Jeep Cherokee Sport - Classic
    awd · automatic · Misc Vehicles
    410  4
    93 Civic 4 Door -sold-
    fwd · manual · Misc Vehicles
    Street Build 3K  6
    1992 Eagle Talon TSi AWD
    12.2 @ 120 · 1G DSM
    Loading...
  6. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    5,360
    2,672
    Joined Nov 14, 2013
    Independence, Kansas
    CTS come unplugged??
    Street Build 4K  29
    14.74 @ 117.04 · 1G DSM
    1K  14
    1990 Mitsubishi Eclipse GSX
    awd · manual · 1G DSM
    749  18
    1967 Chevrolet Camaro RS
    rwd · automatic · Misc Vehicles
    Street Build 1K  7
    1998 Eagle Talon TSi
    fwd · manual · 2G DSM
    Street Build 6K  13  25
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 · 1G DSM
    Loading...
  7. miguelmcv
    miguelmcv Supporting Member
    2,329
    161
    Joined May 3, 2009
    Fresno, California
    Post some pics of the areas where you worked, some time we can catch something in the pic that you can’t.
    Street Build 533  1
    1997 Eagle Talon TSi AWD
    awd · automatic · 2G DSM
    2K  0
    1995 Mitsubishi Eclipse GST
    manual · 2G DSM
    Loading...
  8. TreWebbDSM
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
    Okay, the car is at my friends shop about 30 minutes away. I’m gonna run by there today and see what I can do and I can post up some pics on here
  9. TreWebbDSM
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
    I waited an hour or two to start it back up but they were pretty much dry before I put them on
  10. TreWebbDSM
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
    Plugs are all 4 wet and everything seems to be plugged in but this
  11. TreWebbDSM
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
  12. miguelmcv
    2,329
    161
    Joined May 3, 2009
    Fresno, California
    Take pics of the complete area not just the connectors. We want to see the engine bay and sensors all around to see if we can catch something.
    Street Build 533  1
    2K  0
    manual · 2G DSM
    Loading...
  13. miguelmcv
    2,329
    161
    Joined May 3, 2009
    Fresno, California
    What car are you working on (1g a/b, 2g a/b )?
    In a 2g there are 2 triangle connectors, a crank and a the AC compressor connector which they both can be plugged to each other, make sure you didn’t connect the crank to the ac compressor, otherwise it will never start.
    Street Build 533  1
    2K  0
    manual · 2G DSM
    Loading...
  14. TreWebbDSM
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
    Not sure how good the pictures came out but I tried to get most angles of it, I can take off the intercooler piping to clear up some space. The plug wires aren’t connected im just covering the plug holes because I’m going to do a compression test in a few
  15. TreWebbDSM
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
    2ga
  16. TreWebbDSM
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
    Where are those connectors located
  17. TK's9d2TSi
    3,083
    1,198
    Joined Sep 11, 2017
    Cincinnati, Ohio
    4 1 2 3
    379  3
    410  4
    Street Build 3K  6
    12.2 @ 120 · 1G DSM
    Loading...
  18. TreWebbDSM
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
  19. miguelmcv
    2,329
    161
    Joined May 3, 2009
    Fresno, California
    They are at the right side of the head.
    Check the ac compressor connector and the crank connector they both are identical so check you have the right one connected to the crank sensor.
    Street Build 533  1
    2K  0
    manual · 2G DSM
    Loading...
  20. TreWebbDSM
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
    Than
    Thanks I’ll give it a look
  21. motomattx
    motomattx Proven Member
    2,325
    973
    Joined Dec 9, 2010
    wampum, Pennsylvania
    It looks like you have number 3 spark plug wire on number four cylinder.
    Drag Race Build 4K  24
    Loading...
  22. TreWebbDSM
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
    The plugs aren’t in it currently, I just have the plug wires in the spark plug holes so nothing goes in the motor
  23. ryan_c2g
    ryan_c2g Probationary Member
    14
    3
    Joined Jan 2, 2013
    corpus christi, Texas
    Have you checked your transistor? Make sure it's plugged in properly, check your connections too in case you or someone else didn't pull on the pins from them, probably not making contact with a sensor. Also, as stated above, the "triangle" connections, I had that happen to my self before, swapped them and didn't turn on. Double check
    363  13
    1997 Mitsubishi Eclipse Spyder GST
    Loading...
    TreWebbDSM likes this.
  24. TreWebbDSM
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
    I’ll check again on Thursday when I go mess with it, and I put a new transistor in 3 weeks ago
  25. TreWebbDSM
    18
    Joined Mar 18, 2020
    Roanoke, Virginia
    Also after I changed the gasket it started and there was a terrible noise so I shut it off for a few minutes and turned it back on, it idled steady til it was warm but when I went to rev it and check the throttle response it just misfired and shut off. That’s when it never really started again
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
