Change T-Belt Void Warranty, HELP?
Lordpaxin
1,890
15
Apr 21, 2003
Jackson County, West Virginia
The supplier of my JDM swap, has a 6 month Warranty.
I was told I MUST replace TBELT system. The vendor of the JDM said that the warranty is void after Any modifications are completed, Including T belt.
what can i do?
I dont want ti install the motor, run it, then pull it agin for the tbelt.
should i Just run fuel to it, and run it in the CLIP, before i take it out, and swap the belts.
any ideas?
thanks
Tell that company they're ghey for offering a completely worthless warranty. You HAVE to change the belts, no way around it. You have no idea how old that belt is and it will most likely break in short order if you run it. You have no choice but to void the worthless warranty.
Can I run the engine in the clip, prior to removal and tbelt change, to ensure start?
if so, how do i get around not having the keys to start the ignition
Yes, but dont. Its a lot of work. Send the motor back and get one from a reputable company.
mabye il talk to him. and see if i can work someting out.
  • For sale Jmf race manifold
    6 bolt jmf race manifold throttle flange is for s90 Asking $400 plus shipping
    • spoolinjuice
  • For sale 1g 1G EDM Taillights for sale
    • Shaxzy
  • Wanted 2g Front glass wanted
    Hopefully some has one or has a lead on one but im having a hard tome finding any
    • 2gRhino
  • For sale Dynatek ARC-2
    Dynatek arc-2
    • FWD
  • For sale Used Powder Coated Valve Cover
    Used Powder Coated Valve Cover Black texture with silver letters Was Powder Coated by someone...
    • mjboehm
