Please Support Rix Racing
Center tail Light Removal
richie_gs
Oct 17, 2002
West Des Moines, Iowa
How do you remove the Center tail light piece on a 2g. I can get the two sides but cant figure out the middle one. Is there another panel that comes off in the trunk, or do i just have to reach from the side ones?
You need to remove the middle panel from inside the hatch in order to reach the 10mm nuts from behind the center piece.
i have had all eclipses in the past, and this tsi center tail is a lil different then the eclipses. I need to take the center out, can someone assist me in doing so? Thanks
You have to take out the interior panels in the rear. After that you just unscrew them. There might be a little more, but when you take out the rear interior panel, it's pretty much straightforward. I just swapped my talon lights for eclipse ones not too long ago.
