Gamble97
- 2,648
- 67
- Jan 3, 2006
small town,
Illinois
Hi everyone, I took a long vacation and back and ready to make some more parts. Here is a quick rundown of what I have in preparation for the holiday.
Instead of making 20 new posts I crammed it all in one so we will see how this works out, otherwise I'll have to divide them all up in the future. I'll keep updating the post so keep an eye out.
$100 each / Shipped within the USA
3" Round catch cans
Internally baffled
10an fittings
1/4 turn ball valve drain
1.5" air breather included (not pictured)
Universal mounting bracket
$175 each / Shipped within the USA
10an Sealed Catch can
1/4 turn ball drain valve
Internally baffled
10an Fittings
Milled front face
$20 each / Shipped within the USA
FIAV Block Off Plate
FIAV Bypass Off Plate
$15 each / Shipped within the USA
EGR Block off plate
**BLEM**
Power Steering Caps. These were my first milled projects. Far from perfect but way better than the factory cap. These sit over the existing cap but you will need to use double stick tape, velcro or some other way to attach them together as I milled the opening too large. Some battle scars on the bottom. Only have 3 of these
$20 (pack of 2) / Shipped within the USA
3D printed helmet and key hook.
Black and Orange colors currently. Printed in PETG and very strong.
MDF Eagle Logo - About 6" across
CNC Router just got back to running - Made to order currently
$70 each / Shipped within the USA
Purge block for fabricators. Back purge for t25, t3,t4 & 3" 2bolt exhaust flange
1" thick aluminum
$40 each / Shipped within the USA
2g clutch reservoir cap. **Cap only**
Another one of my first CNC projects. While not perfect still much better than the factory cap. These are finished on the manual lathe so the contour will vary from one to another. This is NOT a replacement cap, this is a press fit cover that fits snugly ontop of your existing cap. Each one is test fit for a good fit before shipping.
3" Round catch cans
Internally baffled
10an fittings
Internally baffled
10an Fittings
Milled front face
EGR Block off plate
**BLEM**
1" thick aluminum
