Please Support Rix Racing
Please Support STM Tuned
Resolved CAS support adaptor?
Cellus
Jul 25, 2019
Skokie, Illinois
soooo, I need some help, I currently have a 98’ 2G with what I’m assuming is a damaged CAS Adaptor
As you can see, the 2 divots are off looking and I assume they’re damaged from improper installation on my end. Now I looked at extreme psi and the one me that I found there is A.) out of stock/discontinued. And B.) looks different
Now I’m assuming this is not a 97-99 CAS Adaptor but rather this is 95-96 CAS? At least I think so
So now I’m in a pickle, anybody know someone that has this? Preferably in the Chicagoland area. If not, anyone?
95-96 have the Cam Sensor on the cam gear. 97-99 which is what you have has the Cam Sensor on the end of the cam on the opposite side of the gear. I might have one laying around my shop. But im in Texas. How soon are you lookin to get it?
The key slides into the cam notches and is held on by the 12mm. It looks to still be usable as long as it sits fully. Which is about 1/4in deep. If so, itll work just fine
Thanks guys, I was actually able to get the key back in after grounding the notches a little. Before, the notches were out just enough to where I was not able to push it in.
