1. Join the Community!
Carbon Fiber Hood Hazing
Posted by amskater, Jan 13, 2009
Please Support ExtremePSI
  1. amskater
    amskater Proven Member
    86
    Joined Oct 4, 2007
    LA, California
    Does anyone know any good ways to get rid of the hazing on a carbon fiber hood?
    239  0
    1996 Mitsubishi Eclipse N/T
    manual · 2G DSM
    Loading...
  2. beyondspexj
    beyondspexj Proven Member
    88
    Joined Jan 2, 2009
    Las Vegas, Nevada
    Mother's makes a good polish to get rid of hazing. but if its too bad then you might need to get the hood recleared.
  3. amskater
    86
    Joined Oct 4, 2007
    LA, California
    does anyone know what Mothers Polish? To get it re-clearcoated id have to get it wet too right? the haze is not real bad but some angles the hood looks great other is doesnt
    239  0
    manual · 2G DSM
    Loading...
  4. mitsubishi9908
    mitsubishi9908 Proven Member
    162
    Joined Mar 24, 2008
    rochester, New York
    you can get a hood recleard. how does that work?
    382  0
    1998 Mitsubishi Eclipse GSX
    manual · 2G DSM
    Loading...
  5. kittay
    kittay Proven Member
    305
    Joined Dec 20, 2007
    Boise, Idaho
    Sand it down to get the yellow'd clear off, then have an auto body place re-clear it.
    Was it VIS?
    388  0
    1991 Mitsubishi Eclipse GSX
    12.384 @ 112.270 · 1G DSM
    Loading...
  6. amskater
    86
    Joined Oct 4, 2007
    LA, California
    pretty sure its not VIS :( I traded my stock hood for it
    239  0
    manual · 2G DSM
    Loading...
  7. eclipse_16g
    eclipse_16g Proven Member
    194
    Joined Oct 8, 2008
    Naugatuck, Connecticut
    just curious where did you purchase the hood?
    1K  0
    1990 Mitsubishi Eclipse GSX
    manual · 1G DSM
    Loading...
  8. mitsubishi9908
    162
    Joined Mar 24, 2008
    rochester, New York
    Mine is a VIS and after a year and a half i started to get white spots.:notgood from the sun. i never new that you had to take care of them.:cry:. I also started to get cracks which i am wondering is normal?:mad:
    382  0
    manual · 2G DSM
    Loading...
  9. xsboost
    xsboost Proven Member
    233
    Joined Apr 21, 2008
    New Bern, North Carolina
    I have a VIS hood. I kept it waxed because I had heard of the notorious VIS fade, but It started fading anyway. It started with small spots and soon the whole hood looked like crap. A friend of mine got a VIS hood and it started doing the same thing so I warned him of what happened to mine. He took it to a body shop where they sanded it to remove the faded spots and put a couple of coats of clear on it (just as kittay suggestet you do). It looked good after that and didn't fade anymore.
  10. beyondspexj
    88
    Joined Jan 2, 2009
    Las Vegas, Nevada
    yup. VIS is known for using a faulty clear coat. any good body shop can sand it down and put a lot better of a clear coat on there. and wax it just like you would wax any other part of your car.
  11. amskater
    86
    Joined Oct 4, 2007
    LA, California
    has anyone taken their hood to a body shop to get theirs wet sanded and a new clear coat? just checking to see what others paid
    239  0
    manual · 2G DSM
    Loading...
  12. Winglessflight
    Winglessflight Supporting Member
    73
    Joined Aug 30, 2005
    Port St Lucie, Florida
    Just as a side note, the VIS carbon fiber hoods, and many others, for that matter, aren't clear coated at all. It's actually a resin, a lot like, if not the same as fiberglass resin used to make fiberglass parts hard and smooth.. I'd actually recommend clearing any carbon fiber component if possible because it ads a degree of UV protection not found in the resin, even if it's brand new. Unless it's bare carbon fiber which isn't at all typical to consumer exterior pieces.
    261  0
    1995 Eagle Talon TSi AWD
    automatic · 2G DSM
    Loading...
  13. talon_swift7834
    talon_swift7834 Proven Member
    83
    Joined May 13, 2008
    Monroe, Wisconsin
    I have a vis hood and it has not only started to crack but has started to become weaker in the center, sort of soft feeling. When I get my new hood it will most likely be from carbon-trix or hi-rev.
    292  0
    manual · 2G DSM
    Loading...
  14. Sarge32
    Sarge32 Probationary Member
    32
    Joined Mar 11, 2008
    Manchester, Pennsylvania
    When purchasing Carbon Fiber parts, you have to be sure they are using epoxy resin. The epoxy stands up better to UV. Also if it cracks you normally will have one crack, it wont spider out. Some doing Carbon work will use Polyester resins designed for fiberglass to save some cash. They dont have the durability Expoy does.
  15. olmytsi
    olmytsi Proven Member
    1,895
    18
    Joined Jan 29, 2004
    Miami, Florida
    All the shops i went to wanted like $3-400 to reclear my cf hood. So i said f it, got another stock hood, put it on the car and trashed the cf hood, it was faded to hell.
  16. mitsubishi9908
    162
    Joined Mar 24, 2008
    rochester, New York
    I will never purchase another VIS carbon fiber hood. I will buy it from another maker. I could not believe how much lighter the carbon fiber hood was though.
    382  0
    manual · 2G DSM
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
