00 Agent
- 173
- 1
- Aug 7, 2003
TexasUS
Occasionally when I'm driving the car will suddenly bog down and start running like a lawn mower. I've found this to be because cylinders 2 & 3 are either getting no spark or no fuel. If I turn off the car and wait for the ECU to kick off then start it back up it runs fine. What's really wierd is that a couple times I've had to do this the ECU would never turn off after I turned the key off and I had to disconnect the battery. So what do you think? Coil? ECU?
