  • Update Your Password Today!
    We have implemented tools to identify member accounts using insecure passwords and will be locking those accounts until their passwords are updated. Don't get locked out of your account - update your password today, and ensure your account has a valid email address on file. Read more here...
Please Support ExtremePSI
420A Car dying
Cfrakes
46
Jun 6, 2021
Idaho
I got a 1999 eclipse RS and whenever I crank it turns over but immediately dies. It takes about 4 times before it actually stays on. Then it also has a issue where it sounds like it's about to die out with the rpms going up and down from 600 to about 1000 rpms. I just got the car as a project and it does have a aftermarket cold air intake. Could that be that cause? Any ideas are appreciated thanks.
Cfrakes
46
Jun 6, 2021
Idaho
Have you checked your compression or performed a leak down test?Do you have carbon build up by the exhaust or any oxygen sensor codes?
Compression is around 190 across the board if I remember correctly. No carbon build and zero engine codes
BLACK'98DSM
3,853
1,411
Feb 9, 2019
Alabama
Would a pcv without a hose connected be enough of a leak to cause it? I know for a fact the IAC is good. Thanks.
Yes that would be a huge leak. The fitting on the intake manifold is 3/8" so I would imagine a lot of air is passing through and causing lean conditions.
Boosted Fabrication ECM Tuning ExtremePSI Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications MyMitsubishiStore.com RixRacing RockAuto RTM Racing STM Tuned
