Please Support RTM Racing
Please Support ExtremePSI
car dying in neutral
TAI92GSX
56
Oct 20, 2002
WISCONSIN
How come when i get into neutral, my car just dies. Not everytime, but when the engine gets hot and then i just put it in neutral when coming to a stop. But when i just let the rpm drop slowly by braking it doesn't die. Anyone know what's the problem?
Play with your idle switch on the VPC and make sure there no caccum leak going to the map sensor.
Lue, its my brother's talon not my 92.
Off topic....how's your car coming? Gonna run her soon, let me know I love to line up with your beast and see how it does against it.
if your venting to the atmosphere on the stock bov, that is probably why
my car has a similar problem as well. i'm curious to see how this'll be fixed because i have no clue.
Check the throttle stop switch located on the back of the TB, it has one wire going to it. Alot of times it will get unplugged, break or be out of adjustment. Pull the rubber boot off and make sure the wire isn't corroded. This switch grounds and lets the ecu know that the throttle plate is closed. Let me know if this helps
Chris
Thanks for all the help and replies. I will look into it tomorrow and let you guys know if the problem is fix.
