Car dies when I coast
Libila
1,100
Oct 13, 2002
Carson City, Nevada
Im really stumped here. My car warms up like it should, then the engine will idel at like7-8 hundred rpm like it should. Then when I drive the car and I start to coast (like with the clutch in or in neutral) the car dies. I dont get it because the car runs fine when im on the gas. Please help!
OK I just went out and tried it agian and now the car idels really low when sitting still if it doesnt die. Could it be the started or alternator?
Ok now that I got thinking about it, something in the fuel system would make sence. Please give me some imput guys!
Even if they dont stay on, it could still be the alternator, do the lights dim at night when you roll the window up or something? You can have those checked at like autozone or something i believe. It is probably something wrong with the electrical.
Yes the lights stay on when the car dies. Im not sure if the lights dim when I role down the windows, I can check. So you guys think it could be alternator?
I figured it out. That fuel injector I had problems with before has a bad o-ring and the upper rubber seal is bad. The reason my car was dying was the car was taking in to much air and not enough fuel so it died. Im going to work now but tomarrow I will go to the dealer and get the injector seal and o-ring set and then friday I will be able to take my fuel rail off and replace that crap.
  • For sale 1g B1H 4 bolt differential
    Hey guys, up for sale is my 4 bolt diff, price is $250 shipped.You must be registered to see...
    • 1cleangsx
  • For sale 4G63 JDM 4G63 Mitsubishi lettered valvecover
    JDM 4G63 valvecover. Mitsubishi lettered along with Diamond symbol. No broken holes or...
  • For sale 1990 Plymouth Laser RS Turbo (NE Oklahoma area)
    Car that I bought to drive for fun but need the money for college
    • InfiniteRevs
  • For sale 4G63 Holset HX Super 40
    Holset super 40 specs t3 .82ar with 3” vband exit, Billet compressor wheel 60mm inducer 86mm...
    • GST2012GSX
  • Wanted 1g 7 bolt oil pan N/A
    I need a 7 bolt oil pan for a 1992 eclipse with delivery to Europe
    • Xtalex
