Please Support JNZ Tuning
Please Support ExtremePSI
car broke down and is leaking green oily mess
coupe_nasty
266
16
Oct 15, 2011
Easton, Maryland
So I was driving down highway. All the sudden car shudders and slows way down and won't drive. Started it back up, motor is fine. But when I put into gear, dosent wanna move. Leaking green oily liquid underneath on passenger side. Jacked it up and in neutral I can turn passenger wheel with my hands but its hard to turn. Please anyone know what the issue is?
Check your CV axle boots.
How is your coolant level?
the bulk of the fluid is directly in line with the inner axel boot, below and to the sides. looks like it exploded.. these are not to hard to fix.. just pull the axel out, peel off the damaged boot, separate the two sections of the axel, wipe them clean, repack with tons of fresh axel grease, and install a new boot kit.. snap axel back in and off you go
ok so i reached under there, and the inner boot of the axle is completely ripped in half. So, my other question is, i checked the other side of the car and the boot is intact but there is grease on the engine side of the boot, all around the axle rod. is that normal?
