cant keep boost
crvttc5r
30
Feb 18, 2003
when i first bought my car it was stock. then i put a boost gauge on it and it peaked at 11psi but would fall off the to like 8 or 9psi. then i put a smic(didn't come w/one from factory) and I removed the bcs restrictor. now i can make 13psi peak but it falls off to like 10psi. is this normal or could something be wrong with my car. someone please help me.
-matt
Normal. Boost will spike and then settle down.
Although you shouldn't be getting only 8psi or 9psi.
-M
Originally posted by crvttc5r
its not spiking, it makes 13 at like 2200 amd holds till about 5000 then drop off to like 10 or 11psi
this is normal too..your just exceeding the turbos limits..what size is the turbo?..the problem is probaly just the turbos capabilities..if its a small turbo then the boost will fall alittle after its peak HP range..or atleast ive gathered..:)
  • For sale 4G63 Parts
    Transmission starter plate fits 2G DSM 7bolt engine for Auto AWD or FWD and FWD Manual...
    • Dsm_canadian_mike
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
