1. Join the Community!
Can't engage into 2nd, 4th or Reverse
Posted by Razor, Apr 16, 2011
Please Support ExtremePSI
  1. pauleyman
    pauleyman DSM Wiseman
    5,361
    1,154
    Joined Nov 19, 2011
    oklahoma city, Oklahoma
    Is the select shoe still in place? At least shift it by hand at the lever before you drop. You can compare that to the shifter being moved with an assistant. It's more likely to be an external issue since it's all 3.
    Street Build 3K  1
    1997 Eagle Talon TSi AWD
    awd · manual · 2G DSM
    Loading...
  2. LilRedSpyder
    LilRedSpyder Probationary Member
    27
    4
    Joined May 2, 2019
    Livingston, Louisiana
    Wym the “select shoe”?? I’ve disconnected both cables and tried repeatedly to get it into any of the 3 gears by hand and it won’t go or even try to go into gear.
    Street Build 214  1
    1997 Mitsubishi Eclipse Spyder GST
    fwd · manual · 2G DSM
    Loading...
  3. pauleyman
    5,361
    1,154
    Joined Nov 19, 2011
    Select shoe is a small cube of plastic at the select levers on the trans. Without it the lever doesnt pull up or down like it should.
    Street Build 3K  1
    Loading...
  4. LilRedSpyder
    27
    4
    Joined May 2, 2019
    Thanks. A buddy of mine sent me a pic of it. And after checking it out mine are still in place as they should be.
    Street Build 214  1
    Loading...
  5. LilRedSpyder
    27
    4
    Joined May 2, 2019
    Got the trans out and opened up and immediately found my problem. That’s a lot of work and hassle for a lil ole pin to be slid outta place. But she’s fixed and currently going back in. Thanks everyone for your input and advice. Hope my experience can help someone else in the future.
    Street Build 214  1
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
