1. Join the Community!
Cant bleed the brakes, no fluid comes out!
Posted by Nico_, Jul 23, 2019
Please Support Morrison Fabrications
Please Support Feal Suspension
  1. Nico_
    Nico_ Proven Member
    69
    7
    Joined Jan 2, 2013
    Piracicaba, South America
    Hey, i just took my car to a shop and we were manualing trying to change the brake fluid and then bleed it. my car is a 95 gsx with abs. We started the car, and then opened the bleeder valves on the calipers in the correct order, and the fluid wouldnt come out, of any calipers, just a few drops, no matter how hard i was pushing the brake pedal. also, the pedal would not low down. it always came back up. I dont know if it matters or not but my abs unit does not work, the abs light is on. The brakes used to work somewhat normal, only a little weak, and now it works like sh**, but still works.
    Any ideas?
    877  9
    1995 Mitsubishi Eclipse GSX
    awd · manual · 2G DSM
    Loading...
  2. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    4,115
    1,661
    Joined Nov 14, 2013
    Independence, Kansas
    If it were mine I'd be swapping out the ABS unit for a non-abs setup. ABS is good.....when it works but a straight shot from the master cylinder to the wheel cylinders makes me feel better when I have to use that pedal. :)
    317  17
    1967 Chevrolet Camaro RS
    rwd · automatic · Misc Vehicles
    Street Build 449  4
    1998 Eagle Talon TSi
    fwd · manual · 2G DSM
    Street Build 3K  21
    1992 Eagle Talon TSi AWD
    awd · automatic · 1G DSM
    Street Build 5K  11  25
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 · 1G DSM
    4K  24
    13.612 @ 107.760 · 1G DSM
    Loading...
  3. ThunderChild
    ThunderChild Supporting VIP
    2,523
    686
    Joined Jan 5, 2012
    Rathdrum, Idaho
    Sounds like the holes for the bleeders are rusted shut or something. Did the shop not offer any diagnosis or information?
    Street Build 166  3
    1990 Plymouth Laser N/T
    fwd · manual · 1G DSM
    266  8
    1987 Toyota Pickup/Hilux
    awd · manual · Misc Vehicles
    Street Build 793  7
    1997 Mitsubishi Eclipse Spyder GST
    Street Build 1K  1
    manual · 1G DSM
    Street Build 2K  10
    awd · manual · 1G DSM
    Loading...
    1990TSIAWDTALON likes this.
  4. Nico_
    Nico_ Proven Member
    69
    7
    Joined Jan 2, 2013
    they removed the bleeder completly, and nothing came out on the rear.Only a few drops in the front, i'm thinking the proportioning valve is bad or there's air in the system.
    877  9
    Loading...
  5. Nico_
    Nico_ Proven Member
    69
    7
    Joined Jan 2, 2013
    it's on my to do list, but right now i just want to know why i can't bleed it. abs shouldnt be a problem in this case
    877  9
    Loading...
  6. silvreclips
    silvreclips Proven Member
    948
    103
    Joined Jul 19, 2005
    Greenville, South Carolina
    I've had to poke something in the bleeder holes before to get fluid flowing
    1990TSIAWDTALON and ThunderChild like this.
  7. ThunderChild
    2,523
    686
    Joined Jan 5, 2012
    Rathdrum, Idaho
    This. I'd bet the holes on the caliper itself are blocked.
    And the abs won't prevent your from bleeding, but the solenoid pack itself won't be bled until you actuate the solenoids while bleeding. It's a PITA.
    Check the calipers, if needed, pull one off and see if fluid flows freely from the line then. If so, calipers are clogged.
    Street Build 166  3
    266  8
    Street Build 793  7
    Street Build 1K  1
    manual · 1G DSM
    Street Build 2K  10
    Loading...
  8. tk106
    tk106 Supporting Member
    1,345
    258
    Joined Sep 11, 2017
    Cincinnati, Ohio
    See what happens when you remove the line off the caliper.
    88  3
    2000 Jeep Cherokee Sport - Classic
    awd · automatic · Misc Vehicles
    116  4
    93 Civic 4 Door -sold-
    fwd · manual · Misc Vehicles
    Street Build 2K  6
    12.625 @ 111.42 · 1G DSM
    Loading...
  9. rabenne
    rabenne Proven Member
    665
    97
    Joined Apr 21, 2006
    Kenosha, Wisconsin
    If they removed the bleeders and got no flow its not an issue of poking thru rust in the bleeder screw. I am confused about your "the pedal would not low down" statement. What are you trying to say here? the pedal goes way down? The pedal does not go down? Please try to reword this...
    Street Build 6K  15
    1995 Eagle Talon TSi
    Loading...
  10. Nico_
    Nico_ Proven Member
    69
    7
    Joined Jan 2, 2013
    what i was trying to say is that the pedal behaves normally, even with the bleeder opened. i still have pressure. they did remove the bleeder and the fluid still wouldnt come out... there was no rust, it was very easy to remove. i'm leaned towards the proportioning valve being stuck
    877  9
    Loading...
  11. 1990TSIAWDTALON
    4,115
    1,661
    Joined Nov 14, 2013
    Crack a line at the valve. The pedal should go down. It has a blockage somewhere.
    317  17
    Street Build 449  4
    Street Build 3K  21
    4K  24
    Loading...
  12. pauleyman
    pauleyman DSM Wiseman
    5,112
    975
    Joined Nov 19, 2011
    oklahoma city, Oklahoma
    I've seen lines collapse also. You can crack each fitting working from the caliper back. When it starts moving you found your blockage.
    Street Build 3K  1
    1997 Eagle Talon TSi AWD
    Loading...
  13. Nico_
    Nico_ Proven Member
    69
    7
    Joined Jan 2, 2013
    Thanks for the help guys, what i think is the weirdest part is that the fluid would not come out of any of the 4 bleeder, it would drop a little from the front, which makes me think the clog might be before the fluid gets to the proportion valve. But i'll clean every fitting i can find tommorrow
    877  9
    Loading...
  14. pauleyman
    5,112
    975
    Joined Nov 19, 2011
    I don't think it's weird at all. I just did a brake job on a ford and the rubber lines were so bad they kept the brakes applied HARD. Same issue, No fluid. Replaced the lines, no more problem.
    Street Build 3K  1
    Loading...
  15. motomattx
    motomattx Proven Member
    1,689
    496
    Joined Dec 9, 2010
    wampum, Pennsylvania
    Take a blow gun, open a bleeder valve and blow high pressure air back through the proportioning valve, sounds like its slammed shut possibly.
    Drag Race Build 2K  16
    1995 Mitsubishi Eclipse GST
    Loading...
  16. ThunderChild
    2,523
    686
    Joined Jan 5, 2012
    Rathdrum, Idaho
    If none would bleed fluid when cracked, I'll go with a faulty bias valve or rusted ports.
    Still recommend picking at the ports of the calipers or compressed air back-blowing them.
    Street Build 166  3
    266  8
    Street Build 793  7
    Street Build 1K  1
    manual · 1G DSM
    Street Build 2K  10
    Loading...
  17. jensenpitt
    jensenpitt Probationary Member
    Joined Jul 24, 2019
    New York, Utah
  18. Nico_
    Nico_ Proven Member
    69
    7
    Joined Jan 2, 2013
    Thanks guys, here is an update: i took the car to another shop, and they managed to bleed the drivers side, front and rear. but there was still no brake fluid coming out of the bleeders on the passenger side, and also the brakes on that side are not working, front and rear, any ideas? as far as i know the proportional valve divides the brakes front and rear, and not by side. and the abs lines have fluid on them, we checked that. Any ideas? Anyway i left my car there so they could check the lines, i have no time or a lift to do that on my own right now
    877  9
    Loading...
  19. Nico_
    Nico_ Proven Member
    69
    7
    Joined Jan 2, 2013
    Well looks like my front passenger side brake hose was clogged, and the proportioning valve is clogged was well, so that explain why no fluid. the front problem is solved, but i will have to ride without a proportioning valve for a while, is there any real danger in that?
    877  9
    Loading...
  20. 1990TSIAWDTALON
    4,115
    1,661
    Joined Nov 14, 2013
    I was going to quote Paul, in the collapsed line thing. My old 67 Camaro did the same thing he talked about. It let fluid in but not back and kept my brakes applied. I had to crack the line at the cylinder to let the pressure off.
    New line (well 2 new lines, both sides) and it is all good.
    317  17
    Street Build 449  4
    Street Build 3K  21
    4K  24
    Loading...
  21. pauleyman
    5,112
    975
    Joined Nov 19, 2011
    Did you really just ask that?
    Street Build 3K  1
    Loading...
  22. Evo joe
    Evo joe Probationary Member
    15
    7
    Joined Jul 20, 2019
    FREEMANSBURG, Pennsylvania
    Good to hear that you figured the problem out but I would replace the Proportioning valve! Just so you have the right brake bias front to rear.
    30  1
    2005 evolution 8 MR
    awd · manual · Lancer Evolution
    Loading...
  23. Nico_
    Nico_ Proven Member
    69
    7
    Joined Jan 2, 2013
    well its either that or leave the car in the garage for two months or so, because it takes a long time to shipp it to brazil, customs here are a pain in the ass unfortunately. I know what the valve does and obviously i wont be driving it hard or slamming the brakes while i wait for the new parts to arrive.
    877  9
    Loading...
  24. Nico_
    Nico_ Proven Member
    69
    7
    Joined Jan 2, 2013
    yes i will do that. we managed to join the lines with fittings and a little bending, but it's all reversible. just have to wait for the news parts to arrive. it's a lot easier to do the right thing when you have the parts available, which is not the case here :/ if i took my car to a mitsubishi dealership i'm pretty sure they would ask what brand is the car. we have zero oem car parts in stock, and the autoparts store only sell chinese crap so... yeah
    877  9
    Loading...
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com White Shed Speed
