gte
- 37
- 1
- Dec 12, 2014
Baltimore,
Maryland
I found these measurements which I believe will apply not only to the HX35 but also the H1C
Is (1) 250mm or 10" and is (2) 169mm or 6.7"? It does not look like that much of a difference from the picture? Could anyone throw a tape across the housing and measure it and take a picture please? I'd like to know the diameter of the compressor housing and turbine housing of the circular portion of the housing, and not the part where the turbine flange protrudes or the compressor outlet protrudes.
I am trying to find a turbo that is a t3 turbine flange, internal wastegate, divided turbine housing, good for at least 450whp and can fit in the spacial constraints that I have to work with.
Thanks
DIMENSIONS:
Length (mm) 224 9"
Width (mm) 250 10"
Height (mm) 169 6.7"
Thanks
