tqmx1
- 667
- 4
- Jan 17, 2007
Sacramento,
California
The only advantage to a oil/water heat exchanger is that it helps heat up the oil when the engine is cold for compleat warm up of the engine.
That is if it can handle the oil pressure. I dont know how much pressure the ATF is under when it moves through there.
Its low pressure like 20psi.
I have a 7-bolt external oil cooler setup im looking for like 50 bucks for it. Its from a evo 3 ss lines and cooler and oil filter housing
