Please Support STM Tuned
Please Support ExtremePSI
can I run T28 on the stock fuel system
shadow1
Feb 7, 2003
Silver Spring, Maryland
I was thinking of a staged upgrade. I'd like to replace my stock T25 with T28. My fuel system is stock. I already have a 2.5" turbo back exhaust, 1g BOV, intake, MBC. Even if I keep the boost levels down (right now I run 16psi on the T25) I figure I'd still make more power than stock. Any suggestions for a boost level (maybe 12-13psi)? I'd like to deal with the fuel upgrades later.
yes you can... however the only difference you will see is that boost will hold until redline.
spool will be the same.. boost levels should stay the same.. only thing is that it will hold the boost till rev limiter. Will you feel a difference, HELL YES, but you still wont be getting the most power out of the turbo.
Its not recomended to run anything over 15psi on the stock fuel system. Get an sAFC, 550's and a pump and then you will trully feel a difference with the turbo upgrade.
btw, are you looking for a T28?
