Camshaft Identification Information
BogusSVO
5,891
318
Jul 1, 2009
Pensacola, Florida
This thread is for tech info/data only. If you do not have anything to contribute that will help others identify what camshafts they have, please do not post. If you do have helpful info, please make sure to upload your pictures to the site so they will not be lost. Posting data without pictures is only partially helpful, so please try and get pictures when possible.
Please follow the steps in this thread for posting camshaft lift info.
http://www.dsmtuners.com/forums/art...-how-figure-camshafts-lift.html#post153121578
Brian Crower 272 Part number BC0101
Right out the box.
spec sheet
The intake cam has a single white band
The exhaust cam has 2 blue stripes
You can see the cam blank number in the last pic (Upside down)
ES4604
Rocker ratio of 1.7:1 was used to figure net lift
Cam lift X 1.7 = Net lift
Stock cams
"B" cam
Base circle 1.178
Toe 1.372
Cam lift .194
Net lift .3298
"C" Cam
Base circle 1.180
Toe 1.372
Cam lift .192
Net lift .3264
"F" Cam
Base circle 1.178
Toe 1.371
Cam lift .193
Net lift .3281
"I" Cam
Base circle 1.180
Toe 1.386
Cam lift .206
Net lift .350
"J" Cam
Base circle 1.180
Toe 1.396
Cam lift .216
Net lift .3672
"K" Cam
Base circle 1.180
Toe 1.372
Cam lift .192
Net lift .3264
Unmarked- Smoother casting cam
Looks stock, Hyundai or Kia ?
R7 On the back of the Exhaust cam
R1 on the back of the Intake cam
Base circle 1.180
Toe 1.395
Cam lift .215
Net lift .3655
"GB 201" Cam
Base circle 1.180
Toe 1.373
Cam lift .193
Net lift .3281
Kelford Cam
** NOTE** NOT all cams from Kelford with have "Kelford" cast into the blank.
More info found in this thread
http://www.dsmtuners.com/forums/cyl...49185-help-me-id-kelford-272-cams-please.html
Green stripe on Intake cam
Yellow stripe on Exhaust cam
Base circle 1.180
Toe 1.432
Cam lift .252
Net lift .4284
HKS Cam
Etched cam grinder markings on the wrench hex of the cam
I cam 264, E cam 272
M006 is the E cam
M003 is the I cam
Base circle I 1.181 E 1.182
Toe 1.414 1.401
Cam lift .233 .219
Net lift .396 .372
Thanks to 007jimmy for orginally posting the above chart.
FP/Comp
Etched into the cam
I Cam
101-201-8I
UX5137-07
Base circle 1.182
Toe 1.420
Cam Lift .238
Net Lift .405
E Cam
101-202-8E
UX5177-07
Base circle 1.184
Toe 1.416
Cam lift .232
Net lift .394
2G Cams ( From a cust head, IDK if they have ever been swapped from another)
GE
I Cam
143
Base circle 1.185
Toe 1.372
Cam lift .187
Net lift .318
E Cam
151
Base circle 1.185
Toe 1.372
Cam lift .190
Net lift .323
  • HKSspeceurope2.doc
FFWD-DKS 272
Notice the thin red stripe towards the front and a thicker blue stripe at the rear of the cam.
The cams are engraved with "272" on the front face.
For other markings , was only found on the Intake cam
GB
And 274
Base circle I 1.093 E 1.100
Toe 1.323 1.317
Cam lift .230 .217
Net lift .391 .369
Note
Seems the stock base circle falls between 1.175-1.185.
Regrind cams seem to be in the 1.120 range.
The FFWD-DKS have the smallest base circle I have measured to date.
This is great. I was just wondering/hoping that someone already started a resource like this.
To all, please post the brand and model of the cams, followed by pics or describe the markings found on them. It would be extremely helpful to the community to have a single thread to go to, to help them identify their cams. I hope everyone will jump on the wagon and start posting. I'll upload my pics asap. I think I have Webcams.
Just pulled these today.
Intake and Exhaust have the same specs.
Base Circle 1.181
Toe 1.395
Cam Lift .214
Net Lift .3638
You can add these to the top post if you want. These markings are on the cam gear side by the first cap.
Not delta's..No real etchings or id, but white paint..
I have 2 diffrent Hyundai heads, I has the 1g sized intake runners, the other has the 2g intake runner size.
I forget which cams cam out what head.
"Circle D" Cams
Intake Exhaust
Base circle 1.181 1.182
Toe 1.395 1.385
Cam Lift .214 .203
Net Lift .3638 .345
This set has smaller letters cast into it than the factory Mitsu cams
Intake "E" cam Exhaust "A" cam
Base Circle 1.181 1.180
Toe 1.392 1.372
Cam lift .211 .192
Net Lift .3587 .3264
Cam cards for the Forced Performance cams.
Forced Performance Turbochargers: Engine
Comp cams E-catalog. (2012)
http://www.compcams.com/Company/CC/Catalog/COMP/Default.aspx
Page 252 for the 4g63 listings
Came across this today,
Posted by Mysticj, and reposted by Whe3ls, and larvaman
http://www.dsmtuners.com/forums/cyl...5367-mystery-cams-pictures.html#post152987072
Post number 13 will answer your question
Have to refer to the letter at the trans side of cams
never mind will just re-post
Originally Posted by mysticj
4G6x DOHC
Listed is the open/close, (duration), cam height, and lift.
Letter= Cam ID mark
Intake
A-26/46 (252) 35.49 9.5mm
B-21/43 (244) 35.20 9.0mm
C-23/57 (260) 35.79 10mm
D-21/51 (252) 35.49 9.5mm
E-16/48 (244) 35.20 9.0mm
F-26/38 (244) 35.20 9.0mm
G-18/62 (260) 35.79 10mm
H-Unassign
I-Unassign
J-21/51 (252) 34.91 8.5mm
K-18/62 (260) 35.38 9.3mm
Exhaust
A-55/9 (244) 35.20 9.0mm
B-Unassign
C-57/15 (252) 35.49 9.5mm
D-54/18 (252) 35.49 9.5mm
E-43/17 (240) 34.91 8.5mm
F-53/07 (240) 34.91 8.5mm
G-63/21 (264) 35.49 9.5mm
H-63/21 (264) 34.91 8.5mm
I-Unassign
J-57/15 (252) 34.91 8.5mm
K-Unassign
Here are some photos of the Graveyard Motorsports 274 cams.
According to their site: 200 duration @ .050 .408 lift
Solid light green paint in the center of the cams.
Intake Cam:
"26 2" notice the red paint line? We will come back to this...
"L" or "7" depending on what way you look at it.
Exhaust Cam:
No other clear markings on the exhaust side.
"GM 274" engraved behind the cam gears.
Now the intake cam had the red paint on it which leads me to believe this was another aftermarket cam size already because the previous engraved number was ground off.
You can see a tiny bit of the previous engraving on the right side of the dowel..
:hmm: Well, they are regrinds after all.
Originally posted by BastardDSM
http://www.dsmtuners.com/forums/cylinder-head-short-block/464400-delta-hks272-regrind-info.html
Been gonna do this for a while... Finally strapped the degree wheel to my shortblock, installed solid lifters, and measured the cams.
These were sold to me by Delta, as HKS 272 profile, all measurements taken with zero valve lash, installed with AEM TRUE TIMES ZEROED OUT. My block was decked .010", and the head .005".
They are .394" peak lift on intake, and .385" lift on exhaust.
Timing at .001" lift:
IVO: 25 BTDC
IVC: 67 ABDC 272* duration seat to seat
EVO: 72 BBDC
EVC: 24 ATDC 276* Duration seat to seat
Timing at .050" lift
IVO: 6 ATDC
IVC: 36 ABDC 210* duration @ .050" lift
EVO: 35 BBDC
EVC: 5 BTDC 210* duration at .050" lift
Also, I am running JE pistons pn 208478, at zero deck height, with a felpro gasket.
Piston to valve clearance:
Gears fully retarded: (-12*)
Intake: .220"
Exhaust: .070"
Gears zeroed out:
Intake: .150"
Exhaust: .170"
Gears Full Advanced: (12*)
Intake: .050"
Exhaust .250"
My old standard wiseco's have bigger valve reliefs.
This is 4-year old thread, but the info is still useful.
Anyway, here's an update on how to 'correctly' identify which stock cams you may have...
The letter IDs near the cam gears are not the correct cam IDs.
The workshop manual indicates that the cam ID letters are stamped on the rear of the cam, meaning the CAS side of the cam.
I just validated this as I have a set of cams embossed with 'G' on the cam gear side, but had 'F' on the CAS side of the cam.
Actual measurements of the 'G' cam validates it to be 'F" based on the list provided by mysticj @ 4g61t, and quoted by Dale above.
Here are the 'real' G cams from a Galant AMG...
Why do they make cam identification so difficult?! I've got these in my car and I'm pretty sure they aren't stock since it always sounded somewhat cammed. My Exhaust Cam is stamped with G and 4 dots, and the number "222" also stamped on the back of it, however it has a long number stamped on the actual rear of it and the letter "J" (seen in the pictures). My Intake Cam is stamped "H" with 6 dots, and 292" but has no other stamps on the shaft rear. Can anyone ID them?
INTAKE:
Base circle 1.185
Toe 1.378
Cam lift .193
Net lift .3280
EXHAUST:
Base circle 1.181
Toe 1.374
Cam lift .193
Net lift .3280
Help , why kind of car use this camshaft?
In with "K" ,Ex with "L".
Or "K" and "L" original from which engine?
Post #2, 12 and 13 have those letters on them but they aren't saying what they came out of, but a 4g63T obviously.
is jasma 272 camshaft batter than my?
My camshaft is mix, not original evo3.
One is "k" in other one is "L" Ex.
These came out of my 1997 Eclipse GSX. I didn't see anything in this thread or found any results from searching google. Anyone have any idea? Unsure if they are stock cams for this year model.
I Know this is an old thread, but i don't want to make a new post, so here are some specs off of a set of camshafts that came off of a "90 eagle summit 4 door sedan N/T 4g61 dohc, 5 speed manual.
Intake cam: ID marks by cas side [14] [9] and stamped [0]6] R3
Note: green paint on both camshafts.
Base circle. 1.183
Toe. 1.388
Cam lift. .205
Net lift. .3485
This is using bogusSVO math of 1.7×.205=.3485
Exhaust cam: ID marks on cam near cam side of block [1][2] [9]
[0][6] R4
Base circle. 1.184
Toe. 1.375
Cam lift. .191
Net lift. .3247
This is again using bogusSVO provided Math, in the link above on his post. 1.7×.191=.3247
