chodaboy3545
- 79
- 0
- Aug 30, 2007
Pueblo,
Colorado
I am looking to get rid of my talon. It is built and dyno tuned. The motor has 1500 miles since the rebuild. I have the dyno sheet and it came in at 405hp uncorrected at a mile above sea-level (colorado springs) with 18lbs of boost on an FP Black. I tuned to 18 for break in and planned on going to 25-30lbs. Car has no rear interior just the 2 recaro front seats. It is setup for nitrous but never ran or tuned for it. Looking for $9500. I just don't have time for it anymore. Located in pueblo colorado.
95 eagle talon mods list:
FIC 1650cc injectors
FP Black turbo
FP exhaust manifold
Tial Blow off valve
Megan racing 3” turbo back exhaust
Eagle rods
Eagle crank
Felpro mls head gasket
Felpro head and block gasket kits
Weisco 10:1 E85 HD pistons
Kelford 272 cams
Gsc valves standard
Beehive springs
OEM rocker arms
Walbro 450 fuel pump
AEM fuel filter
AEM cam wheels
Gates timing and tensioner belts
Mishimoto radiator and shroud
ARP main studs
ARP L19 Head studs
APR flywheel bolts
Fluidampr crank pulley
ACL oil pump
ACL oil case
ACT 4 puck stage 3 clutch
NGK plugs
nitrous system w/ heater
Tial 44mm wastegate w/ custom dump
Stop Tech Big brake kit
Jacks HD Ultimate Synchro 5-speed Transmission
Auto Meter digital afr
AEM fuel gauge
DSM Link v3 Full
Speed density
E85
FP Black turbo
FP exhaust manifold
Tial Blow off valve
Eagle rods
Eagle crank
Kelford 272 cams
Gsc valves standard
Beehive springs
OEM rocker arms
AEM fuel filter
AEM cam wheels
ARP main studs
ARP L19 Head studs
APR flywheel bolts
ACL oil pump
ACL oil case
NGK plugs
AEM fuel gauge
DSM Link v3 Full
Speed density
E85
